Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp photosmart C6180 all-in one
I have lost the manual. How do I set up the fax option in order to receive faxes.
  • 589 Answers
Your manual can be viewd / downloaded / printed here, directly from HP:
http://h10032.www1.hp.com/ctg/Manual/c00753187.pdf
The fax setup section starts on page 33.
Posted on Apr 22, 2008
How can I run a fax test on my printer?
You can Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
Once your fax is received by the HP Test Fax Service, we will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
Mar 25, 2011 | HP Photosmart C6180 All-In-One InkJet...
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
What button do I press on HP C6180 to manually receive a fax
go to the menu and set it to receive fax manuall..also check your manual...hope this helps...ITTech7574
Aug 28, 2009 | HP Photosmart C6180 All-In-One InkJet...
My c6180 will not answer incoming faxes. I can send faxes OK
you need to scroll throghthe menu options,go to fax settings and set the auto answer to on.Still does not work thenc hk out your Distinctive ring pattern from your telephone servie rpovider and then select the same in the fax settings menu.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Can fax out but not receive faxes
-You should have a number (fax number) for it in order to be able to receive incoming fax.
Good luck
Mai
Jan 18, 2018 | HP Photosmart C6180 All-In-One InkJet...
HP 7280 fax interrupts phone calls
Set the fax to MANUAL MODE, you will then have tp press START to receive a fax.
Dec 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart C6180 All-in One Series prints out a Fax Log after each Fax sent, How do I change the setting so that it prints a Fax Log only on request
Press the Fax Menu button twice to get to the Fax Menu to select or change Fax Options. I didn't see Fax Log in the manual, but I think they refer to it as a Fax Confirmation.
The only reference I saw in the manual was this:
"Note If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes."
Oct 20, 2008 | HP Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
258 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
