Question about HP PSC 2210 All-In-One InkJet Printer
Check Cartridge? What am I checking for? - HP PSC 2210 All-In-One InkJet Printer
    President:
  • 1,138 Answers
The ink cartridge..
See the actual image of this cartridges, the black(H56) and color(H57)
Posted on Jul 21, 2010
    President:
  • 2,571 Answers
That it installed correctly, and that it is not empty.
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
My hp 1010 prints only the first page. but from the second page it gives blank print. please help
shake the cartridge well and put it back & check, replace with another cartridge, check half test page if no print on paper check on image on cartridge drum( while printings approx half page open the door remove cartridge & paper check print on paper,on cartridge drum) check transfer roller & replace
If no image any ware replace "Power supply PCA"..
Sep 10, 2011 | HP LaserJet 1010 Printer
Replaced black cartridge...error light continues to come on. I have replaced the cartridge several times and never had any issues until now. Is it possible the cartridge is faulty? HP 5610 All-In-One
Verify any rat bite *check with new cartridge *check with out cartridge see the error message if its detecting the cartridge not installed, install & see the msg,* Check trailing cable *carriage assm * formatter..
Sep 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Display has "remove and check
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 11, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Check cartridge check print paper light and
remove color or black cartridge, close the lid, let the printer initialize, and then reopen lid and add 2nd printer cartridge...
this should sove the problem
Nov 30, 2009 | HP PSC 1210 All-In-One InkJet Printer
CHECK PRINTER CARTRIDGE SHOWS UP EVERY TIME I TRY TO TEST? HAVE TRIED NEW CARTRIDGES AND OTHER CARTRIDGES KNOWN TO BE WORKING BUT STILL GET CHECK PRINTER CARTRIDGE?
Hello sir; Make sure the cartridge you buy is OEM not refurbish, check all the cartridge install right, if still have problem that's means cartridge senser defect.
Aug 05, 2009 | HP Office Equipment & Supplies
HP LaserJet P2015 cartridge refill
The simplest way to get around this check is to have atleast 2 cartridges. The printer checks the chip to check if the same cartridge is installed again. By refilling a different older cartridge and installing it you can fool the printer and get around this check.
Dec 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Cartridge problem
1. remove the cartridge and check the cartridge no. is it supported or not
2. if its supported then clean the cartridge contact and carriage cartridge contact with clean cloth and then check
3 some time what happen if color carteidge sircuit is gone bad then also this issue is comming so please check with new pair of cartridge
if issue same after done these steps then go to the neareast service center might be carriage pcb or flux cable or logic pca one of these part might be goes faulty
Nov 03, 2008 | HP Officejet 4110 All-In-One InkJet...
Remove and check color cartridge
Sounds like the contacts are dirty. A cotton swab and some rubbing alcohol might help.
Sep 19, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Remove and ck right cartridge
Once remove both the cartridges from the all-in-one and then clean the copper contacts of the cartridges and then put only black cartridge and check for the message displayed on the all-in-one if it even reads check right cartridge then the issue is with the all-in-one hardware. If it reads insert right or color cartridge then the issue seems to be with the cartridge.
Remove the cartridges from the all-in-one and power cycle the all-in-one and then reset.
Now insert the cartridge and check for the result. If the issue still persists then check the expiry date on the cartridge and once replace the cartridge and check for the result.
May 27, 2008 | HP Officejet 7210 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
201 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
