Oliveti copier d-copia16W
We have bought one Oliveti digital copier model: d-copia16W, the toner cartridge which comes with the machine has been finished now but unfotunately that cartridge is not available in local market.
Some of my friend told me above Oliveti model is simialr with Sharp AR-5316. I have tried the cartridge of Sharp AR-5316 but it did not work and some error appears on display.
Can anyone help me out to solve my problem.
    Problem Solver:
  • 13 Answers
If i can agree with ur friend that machine might be similar to sf 5316 so you mentioned a code that appeared on display. the question is if that code is F2 and if the old toner cartridge is exactly simslar to the new one you got from sharp, then the solution i tell you is to replace the plug in pin located at the rear side of the cart. above right the set of gears tied with two screws by the same part from the old previous cartridge. then re install the cartrige and switch ON
Posted on Apr 28, 2008
I need to change my toner cartridge, cant figure out how to get it out , Airborne
Hello
If you open the side cover on the right side of the machine then you will be able to open the front cover.The toner cartridge wil have a green lever if it is not broken off.lift the green lever gently.pull the lever to your side.(Out of the machine to the front). the toner botle is inside this cartridge.Now you wil be able to take it out.Make sure the top of the cartridge come out with the botle.If not it wil stil be in the cartridge. replace the toner botle in the cartridge and push it back in to the machine and push down the green lever,close the front door and the the side door.your machine should load toner to the pcu now.Good luck
Jun 13, 2011 | Gestetner DSm515pfd Digital Copier -...
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
AFTER REPLACEMENT OF TONER CARTRIDGE LED IS BLINKING MODEL AR-5316
hi,
blinking led after replacement of toner cartridge is normal , you have to wait till it gone .
how ever if you feel it take along time then you must check the toner cartridge and reinstall it properly if the machine still blinking you may have to change the developer.
thank you for using fixya
Feb 01, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Install cartridge message displaying on my machine
When your cartridge is not adjust properly.
install your old cartridge.If this massage again may be your machine .Right side drum charge lock not adjust.Or machine ready so problem on cartridge.
Cartridge part no T series toner cartridge SG 35 is appropriate model.
Jan 26, 2010 | Canon imageCLASS D320 Digital Copier
Code error c0070, Minolta EP2050 Copier
C0070 means that your toner bottle is not rotating properly. First thing is to remove the toner bottle from the machine. Close the front door and let the machine run. This may take several minutes maybe even 10. If the code does not come back and once the machine has stopped then re-install the cartridge and let the machine add toner. If no code comes back you are fine. If it comes back after re-installing the cartridge you have a small plastic drive coupler in the hopper that has cracked or there is toner on the rotation sensor. Kind of a common problem on these models. If this happens just reply with a comment and I will point you to the parts you might need.
Most of the time tho this code is a result of an improperly installed cartridge or a cartridge from the wrong model. Should be 201A toner.
Good Luck
Jan 02, 2010 | Office Equipment & Supplies
I have a PC 25 copier. I am getting black streaks
Run a copy and shut the machine off when the copy is half way through. Open the machine up and remove the toner cartridge. Turn it over and slide open the flap that covers the drum. If you see toner streaks on the drum surface similar to what you see on the page you have a defective toner cartridge. Most likely the toner you bought is remanufactured as this machine is very old. Maybe you can return it for another.
Oct 18, 2009 | Canon Office Equipment & Supplies
Getting LCD Error: Toner not set Insert Toner
Sometimes what causes the problem is the black cartridge guide on the inside rear of the machine. It comes loose and so when you put your cartridge in it does not line up with the contacts properly. The parts cannot be ordered seperately. It comes with the whole rear assembly. The part # for it is HM1-0244
Feb 14, 2009 | Canon imageCLASS D320 Digital Copier
Problem with changing the Toner Copier Cartridge
F2 has to do with a toner sensor not working. It could be the replacement cartridge is missing something. Make sure you use a genuine Sharp toner cartridge and that should take care of the problem.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Manual for Sharp AL 800 digital copier
hi im jules_09.you need a new toner cartridge for the copier when the toner light comes on it indicate the cartridge is empty.buy a new cartridge there is a instruction on the packaging that will guide you to install it your self
Dec 01, 2007 | Sharp AL 800 Copier
76 people viewed this question
k24674
jasbo
jasbo
