There is a pop up screen that says "OUT OF RANGE" and keeps moving from corner to corner around the screen. What do i need to do to fix this?
  • 54 Answers
Maybe your screen resolution doesn't match with the monitor resolution , so minimize you're screen resolution
maybe you can try with 800 * 600 and go up one by one and see which maximun it support
Posted on Apr 22, 2008
The bobbin won't stay in place
Your bobbin is too short. The correct bobbin must be even with the bobbin case. If it is the bobbin case that is moving around then you must adjust the inner rotary hook bracket assy. It must allow the thread to move between the corner (near screw) and the bobbin casing. Rotate the hand wheel towards you to make sure the thread fits between the corner and the casing. Make it as tight as possible without a snag taking place.
Feb 14, 2015 | Brother SE400 Computerized Sewing and...
Tip
How can I get a Wi-Fi for iPod touch?
<p>Make a network connection Wi-Fi in the Settings menu of your iPod touch. Touch can connect to any open wireless network, or to closed networks as the password. If you're within signal range of your wireless network, tap the Settings icon for a network connection Wi-Fi <br /> <p><br /> <p>1. Tap "Wi-Fi" in the Settings menu and make sure the slider Wi-Fi is set to "On." <br /> <p><br /> <p>2. Waiting for a pop-up window appears with a list of available networks. Tap the name of the network you want to participate. <br /> <p><br /> <p>3. Enter the password for the network. If no password is required, the iPod will not ask for one. <br /> <p><br /> <p>4. Select "Cancel" if you have a closed network that is not in the list to close. Tap "Other" closed and the network name and password type of security. Use this option if you have access to a Wi-Fi network is closed not featured in "available networks." <br /> <p><br /> <p>5. Check the left corner of the screen. When connected to Wi-Fi indicator lights. The iPod touch will automatically detect and connect to that network when the signal range. <br />
on Aug 05, 2011 | Computers & Internet
Empowering Technology screen keeps popping up...can't get rid of it
Go to start,type in Msconfig and press Enter.You will see a box with a section labelled Startup.Click on that and look for Empowering Technologies in the list.Any with that description,remove the checkmark and the go to lower right corner of the box and click apply then ok,then restart your computer.That should fix your problem..good luck :)
Sep 01, 2014 | Acer T232HL 23" LED LCD Touchscreen...
Fix a fan on a fan oven
Remove plate at rear of oven remove fan blade 3 screws hold fan in place remove bottom screw incompletely slacken top screws. Remove all screws holding rear panel you have bend top right hand corner of rear panel don't worry if pops back when refitted,best to wear gloves, remove fan replace refit in reverse.
Sep 26, 2012 | Cannon 10476G Dual Fuel (Electric and Gas)...
Magic sing chordless microphone registers "sync' in display. The microphone will not function. If I move close to the module, it will activate again. But if I move far, it goes back to...
Hi danbrielle ,
Depends on the range of your player , if you are able to hear sound properly from a range say 2 meters and it shows disturbance when you go far away , that means the distance that you are from the cordless player is too much for proper and clear sound .
I recommend you to get the best out of your player by keeping it close to you , so that there are no hurdles in sound.
Hope this helps....:)
May 10, 2011 | Audio Players & Recorders
Have Garmin nuvi 1200 that will not turn on. Was working good stopped for a cup of coffe then would not turn on. Tried with car power and battery power.
You may need to reset the unit by pressing and holding the power button until it reboots.
You can also reset user data by holding your finger on the lower right corner of the screen whilst powering up the unit at the same time.
Keep your finger pressed until a pop up window appears. Touch YES to clear all data and return to factory settings.
If this dont work the try below
Carefully pry off the thin frame around the screen using your fingernail. If you look carefully you will see a little finger nail notch. Under that frame on the right side towards the corner is a reset button. Push it and it should fix your problem.
Jan 27, 2011 | Garmin GPS
Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Apr 24, 2009 | Maytag MGR6875BK Gas Kitchen Range
Start menu problem
You should be able to drag your start menu around. Try right clicking on it and there should be a pop up menu, one of the choices should be lock task bar uncheck it then you should be able to move the bar back to your liking.
Aug 24, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
