Question about Boating
Fuel mix ratio for 1939 evinrude 3.3hp motor - Boating
  • 346 Answers
If you use synthetic or newer oils, follow the recommendation of the oil manufacturer.
Being from 1939, a 2 stroke engine would have been designed to run leaded gas and a very unrefined oil that would burn easily in the combustion chamber. Today's gas and oils aren't even close to what they were in 1939.
If you use a synthetic oil, the mfg's recommendation is usually something like 50:1.
Posted on Jul 22, 2010
I have an Evinrude 7.5hp outboard motor.Mod# 8RC1A SN# 0178194. What Year of manufd? How to mix fuel & what octane fuel to use & what oil to use? Help me go fishing, thanks.
91 octane rating ( no e-mix fuels ) and proper outboard oil ( not normal engine oil)
outboard oil has a property that allows the oil residue to stick to the metal bits and helps prevent rust
e-mix fuels absorb moisture and and rusts out steel tanks , destroys rubber components and corrodes aluminium components
the model you have is not listed on any 7.5 hp engine from 1950 to 1958
model number starts at 4434 to 7512 to 7525 in 1958
for a better answer , talk with an evinrude service center who should have a chart listing your motor
units with oil injection are 50: 1 ratio and others are 6 gallons to 1 pint of oil which is around 45:1
I would seek advice from an evinrude service center for the correct fuel to oil ratio for your engine
to mix the fuel , put the oil in first then the flow from the bowser will effectively mix it up to start with
then fit the cap on the tank and shake it up yourself
Apr 20, 2017 | Boating
I have a 2013 evinrude etec 25 hp. It has only had less than 2 tanks of fuel ran through it. I took it out today and it would start but wouldn't stay running.
This is a 2 stroke engine - an outboard motor?
Two strokes are quite robust. The usual mistake people make with these engines (think of chainsaws, lawn mowers and hedge strimmers..) is to use car engine oil instead of the correct two stroke oil. Motor oil is completely incorrect and fouls the spark plug.
The other fault is to mix fuel and two stroke oil in the wrong ratio. Most chainsaws etc .. use a mix of 25:1 Too much oil causes oiling and misfiring of the plug. Too little oil causes excessive and fast wear.
Your engine starts up. That tends to suggest that everything is working ok up to a point.
However, look on the following link which deals with an overheating problem for that engine:
http://www.etecownersgroup.com/post/25hp-etec-problem-6107593
May 21, 2016 | Cars & Trucks
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Doesn't seem to use oil? Oil reservoir never seems to go down?
The fuel to oil ratio should be 50:1, which means for every 50 gallons of fuel you use, you should use 1 gallon of oil.
You should see some smoke haze at starting and during running.
Having run an Evinrude that had had the auto pump disconnected in favour of pre-mixing fuel, I would take the boat to a marine engineer to check the pump and delivery. You know it is pretty disastrous when all the oil is burned out.
Sep 10, 2015 | Evinrude / Johnson 135-150-175-200 HP...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
Evinrude year serial number 3014-10340
3014 is a three horse 1955 Evinrude Lightwin. 16/1 fuel oil mix, points set at 0.020 and the NGK B6S plugs set at 0.030". 80-90W marine grade gear oil is used in the gearcase. Nice motors!
Aug 20, 2014 | Sierra International 18-5199 Marine...
Oil weight to use for 1989 evinrude 2 stroke 90 hp outboard motor
The oil is mixed with the gas, just buy 2 cycle engine oil and follow ratio mixture
Sep 29, 2009 | Boating
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Boating Logo
244 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
