Question about Mitsubishi WS-55513 55" Rear Projection HDTV
TV will not say on.
Green light comes on for a few seconds then goes off. Tried reset button get blinking light for several seconds same results. TV is connected to surge protector. Tried pluging tv dic\rectly into wall outlet same results.
Mitsubishi projection tv
Model WS65511
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the no# of times the green light blinks, I mean is it like 2-2, 2-3… that its blinking or it blinks continuously, please post back so that I can assist you further.
Thanks
Rylee
Posted on Jul 21, 2010
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
