My canon mf6550 printer shows download connected every time I start it up. Sometimes it also shows an error code 7701. I have tried restarting numerous times. Every once in a while it will work but then it goes out again. What shall I do. it seems liek a software issues?? Jason
  • 4,281 Answers
IF your printer screen show error 7701 message on printer screen then it is printer issue for that make sure printer show green led flash pull ink cartridges and reconnect.Make sure there is not any paper jam inside the printer . Reset all settings of printer to defaults with printer menu button . But if it show green led then you need to reinstall driver after uninstalling old driver. You can download driver from below link. Click here Click on above link select os then download driver then install.Then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 21, 2010
My canon ir 1020 cannot print or photocopy
Try this website:
http://fix-kit.com/Error-Code-Canon-Repair/repair/?nid=1&dist=GS&uq=error%20code%20canon&cid=16563356885&vx=o
Jan 15, 2013 | Office Equipment & Supplies
My canon imageclass mf6550 shows download stayby. how can i do right now?
I have seen this fault before on the 6550. It for some reason it thinks you are updating the firmware.
I suspect you have lost the firmware in the scnt board. You will need to download it from canon's site and follow the instructions to update the firmware. It may just work. If not then the scnt board is screwed and will need replacing.
Apr 27, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
I have a Canon MF 6550 copier receiving service code 197 why?
good day Sir,
To clear the error clear the paper path and remove power for about 8 to 10 seconds.
Try to read the service manual of you printer. here's the link below where you can download your manual.
Manual
Jul 30, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Cannon mf5750 shows download 7701 connected and don't do anything else. how can i fix it?
Copies are coming out really poor with stains on them. Think its the transfer roller that requires replacement. Is this something I can do myself or do I need a technician?
Jan 29, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
CANON MF6550
The error you are describing is usually cause by a bad cartridge but if you have tried a new Canon cartridge because refills will cause this a lot then we would need to look internally. If you look inside the unit (cartridge removed) on the right hand side towards the bottom you will see 3 flat metal plates. These are called spring plates when you push on them they should move in and out check and make sure they are not bent or depressed in you can try and use your fingers to fix them if they are. If not this unit would still be under the 3 year manufacture warranty call Canon they should give you service options. 800-828-4040
Jan 28, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon imageCLASS MF5770
Download connected is a sign that it has some how got into a firmware update mode. If reseting the unit with all cables (USB and Phone) disconnected for about 2 hours doesn't resolve the issue it will require servicing
Jan 26, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Download connected
I have the solution to your problem
Jan 14, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
284 people viewed this question
k24674
jasbo
jasbo
