Question about Goldstar MV-1526 Microwave Oven
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
  • Goldstar Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=-=-=--
Posted on Mar 27, 2011
What would cause my Goldstar microwave to stop heating and the tray to stop revolving?
if timer and all other controls seem to work correctly id say a loss of high voltage section in microwave power generation part there can be several reasons for this a profesional serviceman can find more about why ?
Sep 09, 2014 | Microwave Ovens
Lmvm2085st glass tray not rotating
The problem is most likely one or two door switches are bad, usually caused by food partical build up, replacement needed.
Mar 17, 2012 | LG LMVM2085ST Stainless Steel 1100 Watts...
Have power, turntable rotates, lights on, timer works, will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 19, 2011 | Goldstar MV-1615 Microwave Oven
My 2 year old Kenmore Microwave Model 721.66229 just stopped working. The light comes on when you push start, but the tray will not rotate and no heating happens. Help??
heatman101[p][p]
Jul 07, 2010 | Kenmore 63663 Microwave Oven
I have a Goldstar microwave and it is not heating up the food. It is running the lights are on the tray is rotating but the food is not heating up at all.
heatman101//./.
Jun 24, 2010 | Goldstar MV-1526 Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar MV1501BQ no heat
Hi LMGreen! Sorry for the late response a bit busy at work.. Coming back to the problem..
Solder joints on power control board are cracked and/or burned. Inspect solder connections on power control board for deterioration. This usually occurs where the harness connector is mounted to the circuit board. Reinforce and re-solder as necessary. Also check all other solder joints.
Apr 19, 2008 | Goldstar MV-1501 Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
671 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
