Question about Olevia Televison & Video
I have an olevia lcd hdtv "synfaxbrillian" and it turns on and shuts off but it won't let me change channels. whenever I press a button it says "effect for tv only". Really don't want to throw it away, can anyone help!! Thank you.
  • jbelbdas05 Jul 21, 2010
    I have already tried the normal things like unplugging the tv, etc.
  • Olevia Master
  • 5,389 Answers
Is this the original remote, a universal remote or the buttons on the TV? What is your input source? With coax antenna or cable (input as Tuner 1), you should be able to change channels. I've seen the "effect for TV" only message when external speakers are connected to the TV and you try to change the volume. So if you have a set-top box (cable box or other box) with the input coming in as HDMI or component video, for example, you won't be able to change the channels without using the controls for that unit. To check this, try hitting the source button on the remote. Alternatively, press Menu and then use the up/down arrows to get to Main Picture Source. The right and left arrows let you go through the sub menus. Hit Enter to save and Menu to go to the last menu or exit the OSD. Check that the TV has multiple channels found when it does a scan. Channel scanning is in the Setup Menu (icon looks like a toolbox) under TV.
I hope this helps.
Posted on Jul 21, 2010
  • 10,594 Answers
I need model number of your tv that would be written on label pasted at rear to diagnose problem.
Thanks.
  • 4 more comments
    Olevia LCD HDTV Model 237 T11 Syntaxbrillian.
    Thank you for your help!
    the exact phrase is "Only Effect for TV"
  • Shahid Electronics
    Shahid Electronics Jul 21, 2010
    OK, I think tv is set on AV Input, press source button on remote to select TV as video source in tv.
    Tried pressing source and it just took me through the normal modes for dvd player, etc. until back to cable. Even within the other modes pressing any button just says "Only Effect for TV".
    OK, unplug tv from AC wall socket for couple of minutes to get it reset, replug back in and turn it On and check.
    OK, in settings menu, do you see Reset option? select it to reset tv on factory default settings that might fix your tv issue.
Change channel
You can do it by pressing program up/down button at its front panel.
May 02, 2013 | Olevia LT37HVS 37 in. LCD HDTV
How do you autoscan the olevia 232 t lcd hdtv? I connected an antenna and using a uneversal remote. it just sits there displaying 'no signal'
In the remote, select the input as antenna. It might be now lying as some other input. Normally the TV itself searches for channels. If it is not, go to menu in the remote control, select install-auto and press ok.
Jul 04, 2012 | Olevia LT37HVS 37 in. LCD HDTV
If I try to use channel up or down it will only mute the sound and not change the channel
A question for you-----only with the manual buttons or with the remote as well?
Jun 11, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Olevia tv won't auto program you can punch in numbers but you cannot channel up it goes into mute
problem with keyboard on set front or side===likely defective switches under the plastic buttons.
May 13, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia lct tv can't do a channel auto scan
first check the batteries in the remote to make sure they are not low and then have the remote tested most repair shops do it free.
Mar 14, 2012 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia TV will not change channels using the remote or buttons on the TV. When I push the channel up or down button, the tv mutes. It will change to 1 channel using the return button. I have tried...
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Apr 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
77 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
