My computer restarts before installation completes
I have downloaded a driver (VIA Vinyl Audio) for my on board sound card, but my computer always restarts before it finish to install the drivers. tried several times to install but still it resorts before it completes installation.
Can someone help me with the correct drivers
specifications of my computer:
MSCLE266-F
VIA CLE266 chipset
Socket 370 Processor Based Flex ATX Motherboard With VGA/Audio/Lan/USB 2.0 On Board
Processor
Built-in VIA C3 2000+ CPU
Chipset
VIA CLE266 (VT8623/VT8235) two chip AGPset
Supports 66/100/133 MHz Front Side Bus
V-Link 266MB/s high bandwidth North/South Bridge interconnect
Memory
Supports two 184-pin DDR DIMM maximum size up to 2GB.
Support DIMMs of DDR200/DDR266.
Embedded 3D Ultra AGP VGA
Integrated UniChrome™ 2D/3D graphics
Shared memory architecture allows a maximum of 64 MB main memory to act as frame buffer
Embedded USB2.0
480 Mbps data capacity
Backwards compatible with USB 1.1
Compliant with Intel!|s Enhanced Host Controller Interface
Specification Revision 0.95
Embedded LAN on board
10/100Mbps Fast Ethernet LAN on board
Supports IEEE 802.3 and 802.3u standards
Fully compliant ANSI X3.263 TP-PMD physical sub-layer
Audio
AC97 Codec on board to provide software audio solution
6CH DAC, applicable for leading motherboard chipsets.
Extensive jack-detection capability
Precise and advanced impedance sensing
Support 2 stereo microphones recording and playback
Two Ultra DMA IDE Ports
Supports two IDE ports up to 4 ATAPI devices
Supports up to PIO Mode 4 up to 16.6MBps, Multi Mode 4 up to 133MBps with bus mastering
Bus Architecture
One CNR (Communication Network Riser)
Two PCI 2.2 32-bit Master PCI Bus slots
I/O Interface
PS/2 Mini-DIN mouse & keyboard ports
Six USB ports (four backpanel ports, onboard USB headers providing two extra ports)
One 25-pin female printer port
One serial port
One VGA port
Audio I/O: LINE-Outx1 , LINE-Inx1, MIC JACK
Form Factor
Four layers, 23.0 cm x 17.0 cm
Flex ATX form factor
  • henprob Jul 03, 2008
    hello,
    I have a motherboard just describe above. My problem is I cant get it’s audio driver.
    I can’t install VIA Vinyl audio driver b/c of it restart frequently
    Any one can help me please. The south bridge number is VT8235M
    Please help me on getting the correct driver.
  • elltie Nov 13, 2008
    President:
  • 2,351 Answers
Hi wabee,
I'll go out on a limb & ask you if the system was restarting before you tried to install, VIA Vinyl Audio? I'm guessing it did not.
Do not try to install any more. If possible try to run windows update. Here's why. Something does not agree with the download. Either the software Vinyl is corrupt, your current system configuration software does not agree with the software driver or your current hardware does not agree with Vinyl. Even though VIA created both Vinyl & AC97 audio. Its possible windows up might have a software fix or update that will repair or update your install of vinyl driver. If not...
Please uninstall the driver if at all possible & pray it did not over write too many system files. If you’re lucky you can uninstall the driver through add/remove programs.
If not than run windows System Restore.
Was this the link you downloaded from?
http://www.via.com.tw/en/products/audio/
wabee, when windows XP home edition first came out there were a lot of problems with sound drivers & programs like Rioax. They would restart the PC. Restarts are also common with
Certain driver files conflict with irq sharing & cause windows to restart. In your bios where it asks PnP OS, if you set it to yes than windows assigns irq's. If you set as no, than the bios sets the irq's. Do not change your current bios settings until your system is running correctly.
Let’s hope system restore works. Lastly you can turn off the auto-reboot by opening System control panel, click Advanced, startup & Recovery and untick 'Automatic reboot'. Then you can see Blue Screen and then diagnose the problem.
Blue screen fixes. http://aumha.org/a/stop.htm
Let me know how things turn out.
Have more questions, feel free to ask.
Best of luck!
Mike
Posted on Apr 22, 2008
Hi friend this is jaichandraReddy i am a engineering student i can solve your problem..
----> First uninstal vinyl Audio driver
---->Restart your system
---->Instal VIA chipset compatable audio driver
like<AC97,AV-RACK)
----->Then your problem is solve.
r u happy to my suggestion plz mail me.
2 Suggested Answers
  • 56 Answers
SOURCE: My computer restarts before installation completes
GO INTO SAFE MODE REMOVE ALL OLD DRIVERS AND ANYSOFTWARE THAT MAYU CONFLICKS AND RESTART SYSTEM
SAFE MODE MAY ALLOW INSTALLATION OF NEW DRIVERS IF SO DO IT IT WILL HELP YOU ALOT.
IF NOR GOINTO CONTROLL PANEL SELECT NEW SOFTWARE LOAD NEW DRIVERS
CANDYMANGANDY
Posted on Jan 27, 2009
I need a sound card for elitegroup model p4vmm2
is it a sound card?? or sound card drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
http://download.cnet.com/driver-complete-rar/3000-2112_4-210081.html
http://download.cnet.com/via-vinyl-ac-97/3000-2120_4-10163027.html
http://www.boxdrivers.com
using this link you will be able select your drivers
hope one of these will help you
Aug 30, 2011 | Computers & Internet
My mother board audio not support
if your computer came with a motherboard disk the sound drivers could be on it
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
hope this helps
Jul 28, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
I am looking for MSI N1996 Motherboard version 1.6 sound driver PLZ help me
This driver, also known as Vinyl AudioCodec, supports all VIA southbridges with integrated sound, including VT8231/VT82C686A/VT82C686B, VT8233/VT8233A/VT8233C/VT8235/VT8237/VT8287. This driver supports the VIA Six-TRAC (VT1616 Codec). The VIA Stylus driver for the Six-TRAC Codec integrates Sensaura technology realizing a new level of audio performance and functionality. This driver supports DOS sound for VIA VT82C686A/VT82C686B/VT8231 southbridges only. Version 7.0b may include unspecified updates, enhancements, or bug fixes.
http://download.cnet.com/msi-kt4v-bios-windows/3000-2098_4-10162333.html
Latest BIOS update for the MSI KT4V motherboard operating under Windows 95/98/Me/2000/XP. It fixes an issue with auto-detection for on-board LAN controller. The BIOS contained here is exclusively for the MSI KT4V (MS-6712). Version 1.C has support Sempron L2 512K 3000+ CPU. Fixed system reports incorrect message for AMD 3200+ CPU.
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware. SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud,
hope this helps
Jun 28, 2011 | Computers & Internet
There is no sound after instal windows xp, what i can do ?
1.you have to install your sound card driver and other drivers 2.if you don't have them ,then download it from your's manufacturer web site
Feb 04, 2011 | Computers & Internet
No Audio device
You are NOT alone! There are a lot of folks trying to correct this issue. I have been somewhat successful, but not always. The last 'fix' is a VIA download that is supposed to work with all AC97 cards. I had the same issue with the computer I am writting this from, and the sound is working once again. So try the download at:
http://www.download.com/VIA-Vinyl-AC-97-Codec-Combo-Driver/3000-2120_4-10163027.html
And PLEASE let me know if it works or not. The more information I can gather, the more I can help.
Mar 02, 2009 | Toshiba Satellite A10-S177 Notebook
CANDYMANGANDY
Jan 27, 2009 | Abit AX8 NVIDIA VIA K8T890 + 8237 Chipset...
Sir, i need to download an audio driver for my via motherboard.but i cant find it anywhere.an audio codec also support named vinyl deck but i didnt find any downlod link.feeling helpless.thank you.
Something to consider: I did a Google search for "Vinyl Deck Codecs", and it seems vinyl deck to be associated with VIA Technologies, but if I were you I would double check for yourself. I did find this one link, http://www.downloadsource.net/c161/via/ which has a VIA AC97 codec combo drivers pack for several different OS`s, or you could go to Via Technologies, and look at their list of drivers. Note, since I do not know what os you use, type of computer, onboard sound/sounddcard, or even if the via drivers are for sure the ones you need, these hints, are just suggestions/a place to start. It is possible VIA drivers are not even the type you need, but vinyl deck seems to be connected with via. Remember Google is your friend. Good luck, I know the feeling, almost nothing worse than a computer without sound.
Dec 16, 2008 | Audio Players & Recorders
Audio card doesn't install
Vinyl AC'97 Audio Controller Driver Downloads, Vinyl AC'97 Audio Controller Driver Patches
Sep 24, 2008 | Intel Computers & Internet
SOUND PROBLEM
Seems windows lost your drivers or another software package broke the drivers. Have you tried to re-install the drivers?
Nov 10, 2007 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Computers & Internet Logo
2,274 people viewed this question
David Payne
David Payne
