Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
I have Windows 7 Home edition and am having trouble doing a cut and paste or a copy and paste of files from one folder into another. It acts like it is processing but then the top of window indicates "NOT RESPONDING". The paste function never finishes. Is this a known bug in Windows 7? How can I make this work?
  • David Hougen Jul 21, 2010
    Restoring to a month old restore point solved the problem. The black screen finally went away after at least 5 minutes and now the cut and paste works.
    Thanks much
  • 6,993 Answers
this can be caused by resent up date or there might be virus present on your computer which is causing the problem.
Try this: go to start menu, > all programs > accessories > system tool > system restore. When you get to system restore, allow the computer to restore to an earlier point when it was working perfectly, that is, when the cut and paste was function well.
If the restore does not solve the problem, then you can run a virus scan on your computer and restart your computer.
I hope the above solves the problem.
Good luck.
Posted on Jul 21, 2010
    Now I have a really serious problem. I restored back to June 20th which was the oldest restore point listed. I initially built this computer in March. Now when I start the computer after loading windows and before it would normally display my desktop, the screen goes black and just sits there doing nothing.
  • 4,281 Answers
Remove temp files from computer.
Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files.
Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive.
Scan computer updated antivirus it is best antivirus.
Download it's free version from below link.
Click here
Download and install then update it from internet.
Then scan computer in boot time avast scanner.
Then your computer work speedy and you can copy and paste easily.
Let me know if you need further assistance.
Thanks for using FixYa.
    When I typed in run %tmp% I received "Error" could not start C:\Users\Dave\appData\Local\Temp
  • It means your user has not admin rights so it creates this issue.
    Create another user account with admin rights then follow above procedure.
    You can create new user in start menu->control panel->user accounts then create new user as administrator .
    Then follow first email solution.
How to cut copy and paste in windows vista
Cut, copy, & paste in Vista work the same as in every other version of Windows.
Cut or Copy:
  • First, select the content you want to cut or copy. It can be text, graphics, or even files.
  • Next, select Cut (or copy) from the Edit menu. If you prefer using the keyboard, then use Control-X to cut, or Control-C to copy.
Paste:
  • Click where you want to put the content you just cut/copied
  • Select Paste from the Edit menu, or press Control-V.
Oct 27, 2014 | Microsoft VISTA Computers & Internet
Tip
How to copy data from a corrupted user profile to a new profile
Create a New User Profile in Windows XP Professional loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Click the Advanced tab, and then click Advanced. 5. In the left pane, click the Users folder. 6. On the Action menu, click New User. 7. Enter the appropriate user information, and then click Create
Create a New User Profile in Windows XP Home Edition loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Under Pick a task, click Create a new account. 5. Type a name for the user information, and then click Next. 6. Click an account type, and then click Create Account
Copy Files to the New User Profile loadTOCNode(2, 'moreinformation'); 1. Log on as a user other than the user whose profile you are copying files to or from. 2. In Windows Explorer, click Tools, click Folder Options, click the View tab, click Show hidden files and folders, click to clear the Hide protected operating system files check box, and then click OK. 3. Locate the C:\Documents and Settings\Old_Username folder, where C is the drive on which Windows XP is installed, and Old_Username is the name of the profile you want to copy user data from. 4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: • Ntuser.dat • Ntuser.dat.log • Ntuser.ini 5. On the Edit menu, click Copy. 6. Locate the C:\Documents and Settings\New_Username folder, where C is the drive on which Windows XP is installed, and New_Username is the name of the user profile that you created in the "Create a New User Profile" section. 7. On the Edit menu, click Paste. 8. Log off the computer, and then log on as the new user.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Let's edit 2 doesn't work with windows 7 I can't install it, can someone help me?
Installing LE2 in Windows 7:
install a newer version of QuickTime than the 6.x included with LE2
run Setup.exe in the "Let's EDIT 2" folder of the LE2 disc
(do not use SetupMgr.exe in the parent folder!)
enter your serial number
continue the installation until the unhandled exception occurs
Error number: 0x80000FFFF
Description: Catastrophic failure
do NOT close the error window yet!
(otherwise the installed files will be deleted)
use the windows explorer and go to C:\Program Files\Canopus\
(the chosen installation location)
rename the "Let's EDIT" folder, for example "Let's EDIT.save"
go to C:\Program Files\Common Files\
rename "Canopus Shared" to "Canopus Shared.save"
make a copy of the desktop shortcut
(copy - paste shortcut)
make a copy of the "Canopus Let's EDIT 2" start menu folder
now click OK in the exception error window and wait a few seconds
restore the "Let's EDIT" folder name
restore the "Canopus Shared" folder name
start Let's EDIT and adjust the settings
especially video standard (NTSC/PAL) and format (DV/DVCAM)
close Let's EDIT
add the following entries to the registry in order to allow installing 3DRT
(adjust DestDir if installed into a different path)
these entries will also allow installing the 3DRT update
(if you have the updated 3DRT 2.01 version that has the improved 3D PIP)
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Canopus\Let's EDIT\Installation]
"DestDir"="C:\\Program Files\\Canopus\\Let's EDIT"
"SetupVersion"="2.03"
run install.exe in the "3D RT" folder of the LE2 disc
(or install 3DRT 2.01 instead, if you have it)
Apr 06, 2010 | Canopus Let's EDIT 2 (77610158100)
Lost my Outlook Express. exe (using Windows XP). How can I download this and can I get all my "saved" folders on my previous account?
Hope you get lucky with this:
Go into your Control Panel and open Folder Options, under the View tab checkmark "Show hidden files and folders" and uncheck "Hide protected operating system files [Recommended]", click Apply/OK. Now go into Windows Explorer and go to C:\Windows\System32\dllcache folder and open it. There should be a copy of msimn.exe there. You can right click it, choose Copy then paste it into the C:\Programs\Outlook Express folder.
if nothing happens then, For futher and any other technical troubleshooting contact, virenderhasanaccount@hotmail.com
Jan 06, 2010 | Microsoft Windows XP Home Edition
Hdown load pictures from samsung sl420 to my computer
 Downloading stored images
You can download the still images stored on the camera to your PC's
hard disk and print them or use a photo editing software to edit them.
1. Connect the camera to your PC with the USB cable.
2. On your computer's desktop display,
select [My computer] and double
click [Removable Disk DCIM
100SSCAM].The image files will then
be displayed.
3. Select an image and press the right
mouse button.
4. A pop-up menu will open.
Click the [Cut] or [Copy] menu.
- [Cut] : cuts a selected file.
- [Copy] : copies files.
5. Click a folder where you want to paste the file.
6. Press the right mouse button and a
Click [Paste].
7. An image file is transferred from the
camera to your PC.
you can also find the info on page 93 of manual. If you do not have manual you can get here.
http://downloadcenter.samsung.com/content/UM/200910/20091007130902250/SL420_English.pdf
Good Luck
Nov 05, 2009 | Cameras
How do I transfer pictures to a folder
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Depending on the program that you are using, most of the times you can just right click on the file and select copy, then go to the folder you want and right click again and select paste.
Nov 05, 2009 | Microsoft Windows XP Home Edition
How do I fix Files/setup/setup.INI is missing or invalid error
You can copy/paste all the Files onto your hard disk, get the setup.ini file from another home edition CD and copy it into the files/setup folder. If the rest of the files fail to copy too then your setup CD is physically damaged. COntact Microsoft and they will charge you a nominal fee to ship out the replacement disk. For more info visit the link below
http://support.microsoft.com/default.aspx?scid=kb;en-us;326246
Oct 24, 2009 | Microsoft Windows XP Home Edition
Sorry to as such a simple question, but how do I copy and paste using the Evo n600c? Thanks
hi...it is Ok about the question...if u need to try and make copy files just right click the folder or files then click copy then paste what u want location need to copy..GOOD LUCK...Thanks...^_^
May 11, 2009 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Zone Alarm will not start up when I turn on my computer?
You can ADD the "Zone alarm" executable to your windows startup.
This can be done in 1 simple way.
1. Locate the "Zonealarm.exe" in your "Program files" folder. Usually your Program Files folder will be here "C:\Program Files". Just run a search for "Zonealarm.exe" inside this folder.
2. After locating the "Zonealarm.exe" file, right-click on that file. And select "Create Shortcut".
3. After that you'll find a "Zonealarm.exe" Shortcut file or icon inside the same folder.
4. Just COPY or CUT the shortcut file.
5. Now Right click on the "START" button.
6. Select "Open all users".
7. This will open a windows explorer window. Locate "Programs" folder and Enter it.
8. Inside you should locate "Startup" folder and enter it.
9. Once u ar inside the "Startup" folder, paste the already copied "Zonealarm.exe" shortcut file.
10. That's it. Now try re-starting the system.
Thanks
Dec 18, 2008 | Microsoft Windows XP Home Edition
Cut Copy and Paste for Windows Mobile Smartphones
There are none...you have to use file explorer then by using your right soft key click menu, edit, then select either: cut, copy, paste, delete or rename.
Nov 19, 2008 | Samsung Blackjack SGH-I607 Smartphone
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
David
David
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
