Question about Sharp AR-5320 Black and White Copier
Probleme code H4 - Sharp AR-5320 Black and White Copier
I got h4-00 error code in my photo copy machine.
Posted on Jul 27, 2010
    President:
  • 2,072 Answers
Press # * C * , that will put the machine into diagnostics.
Enter the number 14 as if you were making 14 copies. Then follow the screen directions to clear the fault code. Should be enter 1 then press start.
The machine will reset and should be fine.
Posted on Jul 21, 2010
Code H4 comes up when the sharp copier ar-153e is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
H4 normally is the problem with the fuse unit caused by thermistors or therm-state charge them then clean it by sim 14 but first check if the connector and fame then do sim 5-02 to check the lamp status
Oct 23, 2015 | Sharp Office Equipment & Supplies
A problemes h4-00
H4 00 - Heat roller low temperature detection - Fuser UNIT
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key CLEAR key (c) Interrupt key
Main code [START] key Sub code [START] key
Main code = 14
Sub code = 00
Apr 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am getting code H4-01. What does this mean?
H4 means you have a HEAT problem, most likely a bad fuser assy.
Jan 25, 2010 | Sharp AR-407 Copier
Digital Copier AR 5316E error code H4 indicating
An H4 code denotes a low temperature or temperature sensor failure problem with the fuser (the device that provides heat and pressure to bond the toner to paper). There may be a peice of paper or part of a peice jammed up inside the fuser that's blocking the sensor, or the fuser is defective and needs to be replaced.
Sep 18, 2009 | Office Equipment & Supplies
Eror code h4
it means you have a problem with fixing unit! i gues the problem is in the termistor witch controls the temperature of the unit!
Sep 05, 2009 | Sharp AL-1641CS Laser Digital Copier
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code:H4-00
That copier is kind a old. The H4-00 is a fusing error code. The problem is that the fuser is not heatting up right. Mostly it is that
the fusing lamp is broken or the thermal fuse is blown. It will not reset untill the problem is resoloved
Feb 16, 2008 | Office Equipment & Supplies
Sharp ar-5316
I am getting a problem code H4 for sharp copier when i start the machine. what is the problem. is ther any solution for the problem of the said model.
Aug 28, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
151 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
