Question about Toro 42'' Zero Turn Lawn Mower Trailer Package Deal ()
Mower wont start
I have a 42" Zero clearance toro. When trying to start it cranks but wont turn over. what to do. first time for this
boscia
  • 163 Answers
SOURCE: toro lx425 rider mower wont start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Posted on Nov 30, 2008
  • 4 Answers
SOURCE: 2007 Toro LX 425 Riding Mower, slow cranking.
check the starter see if it is going bad or not?
Posted on Apr 18, 2009
  • 86 Answers
SOURCE: I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
Posted on May 16, 2009
SOURCE: Mower wont start.
Mine is new out of the crate. I think it is the fuel pump. No fuel flow to Carb. when cranking.
Posted on May 27, 2009
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
Toro z master 74170 zero turn riding mower will crank but wont start
take air-filter off and spray small amount of starting fluid to see if its fuel related problem.
Aug 14, 2015 | Toro Garden
How do I engage the bagger on a zero clearance toro mower
That's should be something I imagine is covered in your owners manual. Why not try going on their website and downloading the manual in pdf format so you can learn.
Sep 27, 2014 | kawasaki 48'' Toro Com Zero Turn Lawn...
How do I engage bagger on zero clearance
That should be covered in your manual. I'm not sure what a zero clearance mower is actually, are you assuming and making up a name for it?
Toro wont start
Clean the fins on top of motor and engine.
Sep 07, 2014 | Toro TimeCutter SS4235 - 20HP 42 Zero Turn...
Toro ss4235 wont go into gear nor bypass valves wont take it out of gear
try forcing the wheel to move get the ztr rear off the ground and try turning the wheel if dont but pump sqeeled you have a bad check valve or pump is going out i say bad check vale rebuild it
Sep 03, 2014 | Toro TimeCutter SS4235 - 20HP 42 Zero Turn...
Can you jump start a toro zero turm mower with a car battery and jumper cables?
Better to not jump them can burn the leads up. Pull it out and slow charge it
Jul 17, 2014 | Toro NEW 42 TIMECUTTER 21.5 HP KAWASAKI...
Cant turn toro time cutter to the right
You might want to post this question in the lawnmower section so that the proper expert sees it.
Sep 02, 2012 | Toro Mowers - Time Cutter SS4235 42""...
I have 42in toro zero turn. turn the key to crank and all you hear is the sound of an electric motor spinning but mower will not engage and crank
There is a small slined wheel that is plastic which serves to enguage the starter and flywheel.
This is mounted on the end of the starters armiture by a configuration of springs , weights and a small bolt / roll pin.
When the starter turns , centrifigul force is used to raise the plastic splined wheel...
It sounds to me that the splines are all broke off , The mechanism that causes the splined wheel to blossom , or the alignment of the starter has been set off somehow.
Sep 29, 2011 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Apr 03, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Have a 3 year old 42'' Toro Zero Turn never had a problem. Was cutting grass and it died. Will not start, no fire and does not seem as if it is getting fuel ? Does it have a fuel pump or could it be...
That unit has a fuel solenoid that is attached to the carburetor bowl. Over time this solenoid can act up at odd times. You can take off the air filter cover and manually choke the unit and see if it will start up again. I would take it in to your nearest TORO dealer. On the website it has a dealer locator to find the closest one to your zip code.
Mar 28, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 42''  Zero Turn Lawn Mower Trailer Package Deal () Logo
136 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
