Question about Dell DimensionTM XPS 710 PC Desktop
Have a solid amber light on top right of motherboard just replaced the psu due to the fact went through 3 power supplies with this unit and a dell tech installed all 3 plus a motherboard about 8 months ago
    President:
  • 2,571 Answers
Sounds like there is a major problem with that computer, if you have proof that dell has done all this work, and they agree it was not your fault, you probably have a good chance of a replacement computer.
I would think this is time to find some advice from a consumer advice orginization.
Just google Consumer protection advice or similar
Posted on Jul 21, 2010
Amber flashing light GX620
LOL... If you haven't already fried your motherboard by using your modified PSU (And that's a big IF), then you need to buy a new PSU with similar specs and connection plugs (ie. a 24pin main) as the original PSU that came with the PC.
May 31, 2012 | Dell Computers & Internet
I went on vacation and completely unplugged my E520 prior to leaving, upon my return my PC will not even boot. There is now a flashing amber light (no lights on 1,2,3,4 front panel) and the fan will not...
PLEASE READ ENTIRE ANSWER BEFORE BEGINNING:
Sounds to me like your power supply went bad. This is easy to replace however with Dell computers you have to order the power supply unit (PSU) directly from Dell or a Dell store (if those exist?). Unfortunately, they are pretty much the only company that has their own proprietary PSU so you can't just go pick one up from the store (like best buy or the like). It is easy to replace but DO NOT ATTEMPT TO FIX IT!!! Power supplies can KILL YOU. They're cheap and easy to replace. Simply unhook all the power connections and unscrew the screws from the back of your case and it should slide out. I shouldn't have to mention that of course it should be unplugged... Why did this happen? Who knows, sometimes psu's just go bad even though you did the right thing and unplugged the machine before going on vacation. Please be sure to note the wattage as you will need to replace the psu with an equal (or I suggest a little extra from the factory installed) amount of wattage. I hope this helps and thank you.
Jan 18, 2011 | Dell Dimension E520 PC Desktop
Amber light flicks once or twice no sound from fan or anything? What do we need to do
If the power button is a solid amber it is likely a motherboard due to a failed capacitor (Check the capacitors on the motherboard see if any tops are bulging)
If flashing amber, most likely a failed power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Aug 30, 2010 | Dell OptiPlex GX280 PC Desktop
Pc has a solid amber light when i try to turn it on now so i unplugged it. I moved the comp around and turned it on again and it had a solid green light but nothing was on. the third time it went back to...
Hi Thanks for your question
I think you are right about power supply. This would be my diagnose. Be careful with your PC because faulty power supplies may fry your motherboard. I would recommend replacing it. This isn't expensive and it's pretty easy to get done. I hope this helps. Good Luck
May 19, 2010 | Dell Dimension 4400 PC Desktop
My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Jan 04, 2010 | Dell XPS 420 PC Desktop
Dell dimension 9200 series desktop does not start
Most DELL's I have seen with this condition it was either the motherboard or Power supply. If your mobo looks fine (see explanation below) then I would try another power supply first. Use one that has the same or greater output watts. I keep several old ones around for this purpose. If that does not solve it then you may have a failed motherboard. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Be sure to look under the fan shroud also. The dead giveaway will be the fact that you are not getting anything after you change the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail. To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. And remember a bad PSU does not always mean no power, just not enough to run the computer. I disagree with the post by GUEST. If you are having Hard drive issues the amber light will not sit and blink at you. I don't know how many DELL's they have worked on, but most DELL's I fixed had 1 of those 2 problems. If mobo looks good then try a bigger (more output watts) power supply. If you have the 4 tiny A-B-C-D Diagnostic lights on the back, what state are they in (amber/green/off)? This may help us diagnose further.
Apr 09, 2009 | Computers & Internet
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Yello power light, dell
1st remove all PCI cards, see if anything changes.  If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
Sep 08, 2008 | Dell OptiPlex GX260 PC Desktop
Dell DimensionTM XPS 710 PC Desktop Logo
258 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
