Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer door wont open - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
MAH8700AWW washer door wont open
hi adriana it is possible there is still water in the drum if that is the case the door wont open untill you empty it,this can be done by draining the water through the filter drain located at the front of the machine ,i hope this helps .
Dec 29, 2011 | Whirlpool LHW0050PQ Front Load Washer
Door wont open
unplug the washer,remove the lower panel,put your hand under the front panel on right side and pull a level on the door latch and pull the door open.
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door is locked, wont open
remove bottom acces panel 1/4 screw sometimes torx bit ubplug washer reach in on non hinge side against doorshould be door lock latch assymbley, bottom of latch assymbley is a round plastic end thats spring loaded ,pull downward and open door replace door lock assymbley
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have this front loader it wont open I did everything in the book it still wont open what can i do
Disconnectthe power cord of the washer for at least 15 minutes. Then the circuit boardwill reset and you can open the door.
Jan 10, 2011 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool model AWM 6101 door wont open after washing has finished
the door can take anything up to 2 and a half minutes to open anyway but if it takes any longer than this, or will simply not open at all then you will need to get a replacement door interlock switch
May 29, 2010 | Whirlpool LHW0050PQ Front Load Washer
Door wont open
Here is a tip that will tell you how you can get your washing machine unlocked manually...
Washing Machine Door Jammed
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool awm 6141 wont start any cycle as the door open light comes on. the door appears to be latching ok
when my washer is switched on it sounds like the motor is strugeling to spin to the right.
Jan 07, 2010 | Whirlpool AWM6141/1 Front Load Washer
Door will not unlock on my whirlpool washer wfw9200sqa
Power must be on. Hold down the 'end of cycle' button at the right side of the panel for 3 seconds. Wait for 2 minutes then try the door.
Mar 22, 2009 | Whirlpool WFW9200S Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
95 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
