Question about Cell Phones
Memory card my memory card is not reading or showing on the screen on my phone
  • margouzh Jun 26, 2008
    My V9 cannot read the external memory sd card
DUE TO VIRUS IN MEMORY CARD IT IS NOT SHOWING THE THINGS. FORMAT YOUR CARD IN COMPUTER. AND FORMAT IT WITH MMC MEDIC SFTWARE
Posted on Apr 22, 2008
3 Suggested Answers
SOURCE: my phone cannot read my memory card
same happen to my nokia 6680 it was workinf fyn but then when i put it in theres nutin on it
Posted on Jun 25, 2008
  • 6 Answers
SOURCE: LG Vu Cellular phone memory card does not read.
Take all files of the card and format it. Then right click on it go to properties shear it. I got a 4G and it works fine now.
Posted on Jun 04, 2009
Reading memory card
Hi
Try using another memory card, this time of less capacity i.e if you were using say a 8GB SD card, try a 4GB or 2GB one. It could be your phones not compatible with the cards storage capacity.
Hope it helps.Thank you.
Jul 14, 2012 | Samsung Cell Phones
BB 9530 can't read memory card, display insert memory card
My card's properties shows "Generic Flat" probably a linux file system. A windows OS will show the card when inserted in the device but there is no option to format. When inserted in a card reader windows will not recognize it. Resign yourself to using the card in the phone or find a linux computer. Try booting your windows machine from DVD-Rom with Knoppix, a live linux file system. If the card is recognized format to a FAT 32 or NTFS file system..
May 23, 2012 | RIM BlackBerry Storm 9530 Smartphone
My bb 8520 says media card cannot be read. verify that the memory card is formatted. what do me?
The best thing you can try to do is connect the media card to your computer. When you see it show up in "my computer" or "computer" right click on it, and select "format". Make sure the formatting is in either FAT or FAT32. Once that is done, put it back in the phone and try again. If you cannot plug the card into the computer, then use the supplied USB cable for the phone, and plug that in to the computer. On your screen it will ask if you want to sync, enable mass storage or charge only, make sure you select enable mass storage. If you do this your card should be readable on the computer and then you can format it using the same method I described. Just note that if your blackberry gets plugged in, it will show up with 2 "storage cards". One of them is the memory that is on the phone and the other is the actual media card. Make sure it is the media card that you have selected to format.
Sep 13, 2011 | RIM BlackBerry Curve 8520 Smartphone
Lg Neon not reading external memory card: I inserted my external memory card into my LG Neon TE365 phone and the little icon (on the top screen) that indicates weather your phone has received an...
I think putting the card in and out of your phone may have slightly changed the alignment of the card to the connectors in the phone - try entering the card either to the left a little or the right but i have a feeling contact is not being made from the wear and tear. Does the card work in another phone? if yes then definitely not the card... but the fact that you have tried to use 2 different cards im thinking its the phone :(
May 06, 2017 | Leviton Combo Switch Neon Lght - 5226-I -...
When i try to open my memory card it on my phone it shows MSDC read sector error.
Sep 19, 2010 | Cell Phones
Memory card is not working
The reason the memory card is not working could be either the memory card is not working or the phone is not reading the memory card.
To test if it is the memory card,
insert the same memory card into another phone to see if the phone reads it.
if it does not read it, then the fault is from the memory card.
all you have to do is to replace the memory card.
To test if it is the phones memory card slot,
install a tested okay memory card into the phone to see if it will read it.
if it does not read it. then it is the phone. it could be a software problem or a hardware problem.
firs flash the phone with the appropriate software to see if it will work, if it does not, then it is the memory card slot.
To change the memory card slot,
follow these steps,
  1. First remove the battery cover & battery. Remove the two screws you see.
  2. Run your fingernail around the join of the front cover and then remove the front cover.
  3. Now remove the four screws you can see.
  4. The top part of the phone (PCB and LCD screen) can now be removed from the middle chassis.
  5. then you will have access to the memory card slot,
  6. remove it and carefully install a new one,
  7. reverse the process to reassemble the phone back,
  8. test it with a memory card.
take care
Jun 19, 2010 | Nokia 6300 Cellular Phone
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
Why my n95 cannot read memory card? always showing memory card corrupted. when i try to format it shows that the card is in used by other application.
Try to format your memory card and remember, memory card use FAT system. if you format your memory card to FAT32, you can't open it on your phone.
Jan 20, 2010 | Nokia N95 Cellular Phone
Memory card
take the memory card and flash it .
if still not working buy a new memory cart
Mar 13, 2009 | Sony Ericsson W700i Cellular Phone
Mmc
Chances are that the software on your phone has become corrupted. I would advise doing a master reset on the phone and see if the problem persists. If that doesn't help...probably the card slot has malfunctioned. Most probably a reset will slve the problem. Good luck!
Dec 19, 2007 | Nokia 6680 Cellular Phone
Cell Phones Logo
203 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
