Question about Frigidaire Dryers
Frigidaire model GLGR341as1 natural i changed the timer but the little motor on the timer only runs on TIMED DRY and permapress after you rotate the knob past the first click about the 2 oclock position..... put the old timer back in does the same thing..... wired correctly took a pic of it before installing the new one... cant figure out whats wrong.... why the timer motor won't go on at the start of the perma press cycle or the or the auto white cycle
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that you have replaced the timer knob not the timer motor, if this is the case then you’ll have to replace the timer motor completely to resolve this issue as that is bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 21, 2010
Old whirlpool thin/twin Dryer timer old timer M404-G New timer M460-G how to hook up
The problem as stated is that the new M460-G timer does not have the same pins as the old one (because there seem to be a variety of sub-models under the M460-G name). However, I have successfully (at least to provide the timed heat function) used a different M460-G on my Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, I had to figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also by inspection of a wiring diagram at appliance pros dot com
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
c / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)48146720-bbc3-47da-833c-6d50a0cf5df0.jpg
Sep 06, 2015 | Whirlpool Dryers
Dryer ldg490 will dry on timer dry but runs forever on permapress (not much heat) what sensor is bad ?
sounds like bad timer points, they tend to burn and get stuck on some places ?
Oct 02, 2014 | Maytag Dryers
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
A / Gas / Org
C / Motor / Wh
BK / Motor / Wh
R / Gas / Org
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Nov 19, 2013 | Whirlpool Dryers
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
My dryer works but no heat
If your dryer runs, but does not heat the following link will explain how to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The majority of dryer heat related problems are caused by poorly installed, improper, kinked, or clogged ventilation exhaust ducting. Pay particular attention to the section that discusses ventilation. Failure to ensure the dryer is properly ventilated will result in repeated failures of any components you may replace. In addtion, this can become a fire hazard.
If you have any questions, please let me know. I hope you find this information helpful.
Jul 07, 2009 | Whirlpool LER5636P Electric Dryer
Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a thought.in timed dry the timer motor receives constant voltage.so if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Jan 23, 2009 | Dryers
Error E1
dear customer,
most of the time the timers of dryers aren't faulty even though the dryer doesn't run properly in timmed mode. dryer timers have small motors on the back. The motor rotates gears and cams that open and close switch contacts that control the loads in your dryer. A load is something that does work like a motor, heater, light bulb or end of the cycle buzzer. When the timer is manufactured the amount of time each set of contacts will be closed is built in by the timer cams and gears.so i recommend yu to check the follwoing
  • Test the moisture sensor
  • Test the thermostats
  • Test the heating element
  • and finally the timer device.
hope you find this useful. thank you.
Jul 09, 2008 | Dryers
Our Frigidaire GLGR341AS1 Does Not Start
see if you can turn the drum my hand... Makeing sure nothing is stuck in blower fan... if you can... sounds like motor my be bad
Oct 13, 2007 | Frigidaire GLGR341AS Gas Dryer
Washer would not stop
danby parts department: 18000-496-6049
i found the timer for this model: DTT420
timer part # 420.4.05
can be bought for cheap at www.partstop.com or www.topapplianceparts.com
----china part #-
DXT-15f-G
120V 3A AC 2008y10M
Aug 07, 2006 | Frigidaire FWSB7800DS Top Load Washer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
