I can't find a decent manual for your laptop but there will be 2 pins on the motherboard that will say BIOS Clear. Short these 2 pins and turn the computer on. This is the only way to bypass the BIOS password. This operation will clear the BIOS and reset to factory defaults. After the BIOS is cleared, turn the computer off and take off the short.
Find the quarter-sized battery on the motherboard and remove it for a few minutes. There might be two pins nearby that read CMOS reset or BIOS reset. Shorting them together with all power removed, including the small battery, can also reset the BIOS.
I've not flashed a bios on a Fujitsu notebook, but have on lots of others. Most of the time it involves booting to a floppy disk or a USB device containing the bios flash files. It's a simple thing to do, but why do you want to flash the bios? I tend to not flash the BIOS on a system unless I'm having some sort of problem.
Having the same problem my tablet turns on shows epad then android flashes HELP PLEASE!!!!
This means that your epad's inside screen is damaged and this means that your epad is completely gone. You will have to purchase another one. I had the same problem and i had the choice of another epad or an ipod touch, i chose the ipod touch because it has almost the same features as the epad or even better features. I suggest that you order the epad from a chinese retailer.
To flash the BIOS you need to download the BIOS from a link which HP provides.. so contact them and tell them to provide you with the BIOS link..
You need to download the BIOS and install it..
However after removing the RTC battery I would suggest you to hold the notebook power button for 20 secs..
This should remove all the residua power..
I think it will remove the BIOS password...
If it does not work then you could flash the BIOS..
What sayy???
