I bought a Samsung sc-dc164 mini DVD recorder. After taking video on the mini DVD's, I can watch them on my computer but I can not transfer the video from the DVD to the computer. I have a USB cable that came with the camcorder but when I plug it in I am prompted to install the drivers for the camcorder. I do not have drivers for it and I have not been able to find them online either. I have MS Windows Vista operating system on my computer. Any assistance would be greatly appreciated.
  • 2 more comments
  • beatcopper Apr 27, 2008
    I downloaded the drivers and everything appeared to be installed correctly and when I plugged in my camcorder with the provided USB cable the computer made the noise acknowleding the new hardware was found. There was also a message that the new device drivers were installed but I am unable to find the device on the computer to be able to download the video. If there is something I am doing wrong I would appreciate some additional advice. I was under the impression that it should be plug and play.
  • Anonymous Oct 06, 2008
    what about 64 bit....
  • Anonymous Nov 17, 2008
    need the driver for 64 bit
  • toadempole Jan 03, 2009
    i cant find a driver for my samsung to run on vista. the disc with my camcorder only does up to xp
  • 3,037 Answers
Hi
you can download the driver at the following link
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=SCDC164&language=&cate_type=all&dType=D&mType=DR&vType=L&prd_ia_cd=04020200&disp_nm=SCDC164
Let me know if you need any more help
Thank you for using fixya and please don't forget to rate this solution
Posted on Apr 24, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 27, 2008
    You first must be on the following mode above, plus you need Directx 9.0 installed, check to see that you have this set
  • Benjamin Patri
    After downloading the drivers, did you then install them too?
  • Benjamin Patri
    Benjamin Patri May 12, 2008
    download the drivers again and put them in a location that you can find. Make sure you then run the setup utility and place that in a spot that you can find
Open button on samsung SC-DC164
Hello :
Yes it can be repaired . but it's better to take it to a repair shop with the flew off button .
good luck .
please don't forget to rate !
Apr 04, 2010 | Samsung SC-DC164 DVD Camcorder
I recorded a video on my samsung sc-dc 164 camcorder and i used my SD memory card instead of the disc. when i try to play my video from the SD card recording it won't play but can only hear audio from my...
how did you transfer the video from the card to your PC?
did you connect the camcorder to your PC or did you use a memory card reader?
if you can play the audio then what you need is the right video codec for the unit
try searching for video codecs through search engines
make sure that the software that you are using to play the video plays the file format of your video,
try using roxio, then connect the camcorder to your computer via USB, make sure that the drivers are installed, play the video through your camcorder then use roxio to capture it real time instead of the usual "copy-paste"
Jun 28, 2009 | Samsung SC-DC164 DVD Camcorder
Transfering the video form the cam to the computer
i have a samsung sc-d353 and i was wondering if i can transfer the video that i have recorded on the tape and transfer it on to the computer using the usb cord if so how would i go about doing this?
Mar 29, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Recording to dvd RW's from mini dvd's from panasonic camcorder
I didn't understand your question.
All dvd player can play mini dvd's. Why do you want to transfer it on a normal dvd disc???
Jan 04, 2008 | Samsung SC-DC164 DVD Camcorder
Recording
iam having the same problem anyone know why
Dec 11, 2007 | Samsung SC-DC164 DVD Camcorder
Samsung SC-DC173(U)
I've been trying to find out the same information. We went to disney this year lost 3 full dvd's worth. Called samsung all they told me was to use memorex mini-dvd's. Thanks alot ):
Anyways hopes this helps a little.
Sep 04, 2007 | Samsung SC-DC164 DVD Camcorder
Write error
I had the same problem. Called Samsung, they told me not to use DVD+R DL discs (despite their presence in the compatibility table in the manual). They also said DVD+R discs don't need finalizing, which contradicts the manual. I can't get them to play in my PC. For the first two discs I tried, it seemed to get write errors halfway through the disc, as if it had trouble with the second layer. I didn't record long enough on the third to find out. The camcorder still shows video on the third disc, but I can't finalize it and it won't play on my PC. Glad I'm only borrowing this camera. Won't buy a Samsung, and probably won't buy a DVD cam.
Aug 01, 2007 | Samsung SC-DC164 DVD Camcorder
Video not found after finalizing disc on Samsung SC-DC164 DVD Camcorder
Put it back in the Camera and see if it tells you the disc is finalized when it tries to format the disc. If it does then you know for sure it is finalized..
Dec 21, 2006 | Samsung SC-DC164 DVD Camcorder
DVD Camcorder appears to have erased disc mid record!
I know it won't play in a dvd player till it is finalized. Leave it in camera mode, hit menu, and scroll down till you see the option to finalize. If you finalize it, it should play in a dvd player. I am having a problem with my camera(same model) where it won't finalize the disc. Any help out there?
Nov 16, 2006 | Samsung SC-DC164 DVD Camcorder
Televison & Video Logo
812 people viewed this question
Top Televison & Video Experts
