Question about Saws
I'm trying to remove a broken blade holder from my Skil reciprocating saw
4 Suggested Answers
  • 35 Answers
SOURCE: How does one remove a
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Posted on Dec 01, 2008
rowdy45176
  • 2176 Answers
SOURCE: Reciprocating saw-snapped blade-cannot be removed
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
Posted on May 26, 2009
SOURCE: Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Posted on Jul 22, 2009
How do I remove blade that's broken off in a Skil 9216 reciprocating saw?
Turn the release as far as it will go, then tap on something blade down till it emerges.
Aug 03, 2014 | Skil 9216-01 9.0 Amp Variable Speed...
Skil saw stops I bump it it starts then it stops I bump it it starts
The two groves could be caused by the auto stop pin in the brushes but I would also check the brushes are not getting stuck in the brush holders.
Dec 11, 2012 | Skil DWOS 7.5 AMP RECIPROCATING SAW VS...
I am having trouble inserting the blade properly
You press the lever forward all the way, insert the blade, and release. If the holder is getting worn it can be replaced as one complete assembly. Here is the user manual link. It shows how to use the holder.
Skil 9225 manual
The part number for the holder assembly is 2610938752. It is less then $10 and is held on with an allen screw so it's easy to change.
Jul 15, 2012 | Skil 9225-01 9.5 Amp Orbital Reciprocating...
Motor runs but blade does not move
It sounds like you have a problem somewhere between the motor armature and the reciprocating mechanism that makes the blade move up and down. Unfortunately the only parts Skill has available for your saw are the switch, cord, brushes and blade holder You'll could take it apart to see if something came apart that is repairable without parts. If you need parts like gears or motor parts, they are not available.
Jul 08, 2012 | Skil 4390-01 Variable Speed Orbital Jigsaw...
Can i use dewalt blades in my 9215-02
as long as the tang is the same there should be no problem. Most reciprocating blades are universal.
May 22, 2011 | Skil 921502 85 Amp Reciprocating Saw
How do i change the blade in a reciprocating saw?
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 05, 2010 | Skil FactoryReconditioned 920501RT 85 amp...
REPLACE BLADE IN MOD #172.171800 8.0 A, CRAFTSMAN, RECIIP SAW
If you see a set screw where the blade goes, loosen it a few turns. Then run the saw, it should spit out the broken blade. If it has a manual release for the blade, press the release while tapping the blade holder.
Apr 29, 2009 | Craftsman 8.0 amp Reciprocating Saw
How does one remove a broken blade from a Bosch rs20 blade holder
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Saws Logo
124 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
