Question about Tripp Lite Omni 9000 LCD (OMNI900LCD) UPS System
I've been away for about 2 hours and came back to find that my computer and my accessory items that are connected to my battery backup were off. My Tripp Lite lcd was blank. I pressed the alarm button and the lcd came on showing that voltage going into the backup and the storage was full. All of the connected equipment came back up. However there is a "fault" icon on the lcd that is still displayed. what should I do? i'm a professional photographer that spends most of my time in Photoshop and cannot be without my equipment for any length of time.
    Problem Solver:
  • 5 Answers
I would suggest a small double conversion UPS system. I sell Toshiba which is a very high quality and reliable system that is easy to use. If you are interested please contact me
Posted on Jul 22, 2010
Gateway ZX4300 - power adapter problem
Verify all specifications of your previous charger and new chargers/adaptors.
Jun 24, 2013 | Computers & Internet
I've a smart UPS 1000VA SU1000INET I've had new batteries fitted. I put on to charge everything seemed ok. Went back to it about 2 hours later to find the 6 middle lights flashing.
Friend you did not tell us if there was correct output voltage after charging and the voltage after 2 hours. However, there could be a short circuit that drains the batteries,was the system left on for the 2 hours, are the batteries of a standard?Good Luck from Ukachi Edwin
Apr 15, 2012 | APC Computers & Internet
My ups 1000 watts suddenly get off for few minutes than again starts itself .it happens 2-3 times in 24 hours.
Back up devices on the computer creates copies of every new features that are performed. The backup devices default settings may allow to save data every often like 2-3 times in 24 hours. also, the backup devices save settings can be altered to suit user speciifcations. for example, important projects on important files may require to save every few seconds lest any malfuntion that occurs to the computer is misplaced. back devices are considered external structures and should be locate on the computer systems control panel area with a unique description. Clicking on the backup devices logos would allow to manipulate either create urgent backup or space the backup to make the computer faster where back becomes attainabel durign idle hours.( for example, set the computer backup to first tthing in the morning or last at close of computer usage.)
Feb 05, 2011 | APC Back-UPS RS 1000VA UPS System
My battery keeps draining in my starcraft travel trailer evry time i put a fully charge battery in the camper in less then 2hour the battery is dead and with nothing on and all the braker off
Charge your battery, and connect it back to the travel trailer. Use a 12volt test light to make the connection between the cable and negative terminal on the battery.
If there is something drawing power, the light will turn on. Remove the fuses from the DC fuse block 1 at a time, make note of the current rating for each fuse position. When the light goes out, the last fuse you removed is where the culprit probably lies. Now that all the fuses are out, plug each one in, individually, and see when the light comes on. Look closely at the light. Some notorious items that are left on are the antenna booster for the TV, the radio (volume turned down), and lights in the storage compartment. Some fridges will have a small heating strip between the doors. This heat strip may not be turned off with the fridge switch unless it is put into storage mode.
2 hours on a freshly charged battery is signifiant. The average Group24 deep cycle battery, in good condition, has a capacity of approx. 100Amp Hours. Most are able to sustain a load of 20 amps for about 180 minutes, around 3 hours. To deplete the battery in 2 hours, is a very significant current draw.
There are only 3 things that can singly draw down the battery that quick.
1) Furnace - but you would hear this one running.
2) DC Cooling mode on the fridge. Silent battery killer.
3) The breakaway switch for the electric brakes. When the plunger is removed, full battery voltage is applied to the brake magnets. A dual axle trailer may have 4 magnets, at 8 amps each, gives you around 32amp current draw. If pulling the fuses doesn't yield a culprit, the break-away switch is probably it. Remove the plunger, and push it back in. Watch the light as you do so.
Otherwise, look at your trailer connector. If it has been contaminated with road grime and such, it can cause a partial short between the charge and ground terminals.
Sep 08, 2010 | Electronics - Others
Hace a APC XS 900 that said battery needs replacement, unit is about a year old. I replaced the batteries & it lasted about 2 hours & again says replace batteries. I know the new batteries are OK...
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Mar 13, 2010 | APC Back-UPS XS900 (BX900) UPS System
Alarm and battery failure ; Powerware 9102
open the screws and disconnect the battery look the voltage written on it and AH (ampere/hour) e.g.12v & 7ah and purchase same value battery and connect look carefully the +ve &-ve polarity of battery and connect in proper way
Feb 24, 2010 | Powerware 9120 UPS System
Xerox WorkCentre 4150 Error code: 20-800/The machine cannot save the fax settings to memory. Xerox service is required to inspect the backup battery. Faxing is disabled, printing and all other machines...
One of 2 things.
EIther you have to enter the Fax User memory, Or the memory battery has failed and needs replaced.
Here is what the service documentation says.
(4150) During a power-off period, the machine has lost its user memory. Check that the backup battery, PL 1.10 Item 5 is holding its charge of about +3V. If necessary, install a new battery, PL 1.10 Item 5.
Dec 17, 2009 | Xerox WorkCentre 4150 Black and White...
My dell axim x30 backup battery needs replacing. Is this something I can do myself?
i believe if you are a bit of a hands on type of person you should be able to do this yourself.
but not without researching !
read this page, should tell you everything you need to know, from the perspective of someone who had to do the same changing of the CMOS battery.
http://www.mobilitysite.com/boards/x3-x3i-hardware-troubles/96005-x3-backup-battery-revealed.html
or read below:
quoted from: Tenc hi4U
DISCLAIMER : I take no responsibility for any damage you may cause to your Axim. The parts and proecedures described in this guide refelct my own experience with my own Backup Battery (BuB) in my girlfriend's Axim X3. Your mileage, parts, anbd experience may vary.
Tools needed for successful BuB replacement:
1. fine tip jeweler's screwdrivers (helpful if you slightly magnetize the tip)
2. Varta V20HR rechargeable NiMH battery
3. electrically conductive silver epoxy
4. strong needlenose pliers
5. electrical tape or heatshrink (razor blade or scissors to cut to shape)
But here it is step-by-step:
1. Pop little rubber caps from 4 corners of back covers. Disassemble Axim X3 with small jeweler's phillips head screqwdriver. Be sure to plave all parts in a plastic bag or other container (4 scres rear cover, 2 screws near port). Disconnect the ribbon connector towards the bottom of the PCB and the speaker wire (also on the lower portion of the PCB). Backup battery should be the green covered circular item under the pcb).
2. Locate backup battery, Cut away BuB cover, & CAREFULLY use strong needlenose pliers to grip and "roll" the leads off of BuB.Be very careful with the leads.
3. Mix dime sized batch of silver conductive epoxy (do NOT hot solder this battery, heat will lead to BuB damage and destroy lead connection to wire).
4. Apply epoxy to both sides (not too much)and afix respective leads to respective side (red lead goes to +, black lead goes to -). Secure connections with some type of clamp (I used a binder style paper clip, but a wooden close pin or something else that will hold the leads to the BuB while the epoxy cures (Mine took 24 hours to cure).
5. Recover new BuB with protective covering (I use electrical tape cut to the shape of the BuB. Covering WILL have to be form fitting to fit back into Axim BuB "slot".
6. Reassemble and charge Axim and charge.
Sep 07, 2009 | Dell Axim X30 Pocket PC
To increase backup in apc symmentra ups
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 04, 2009 | APC Symmetra Tune-UPS technical support -...
Tripp Lite Omni 9000 LCD (OMNI900LCD) UPS System Logo
504 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
