Question about Canon Pixma MP500 All-In-One InkJet Printer
Error i was trying to on the printer to printer something but when it was usually checking it components, it made a weird sound followed by showing out an" 6000 error"
I have a sharp ER-A450T it is frozen and I have followed all the trouble shooting things in the manual and nothing seems to work...please help
Hi Renee. The first thing to check with this model is whether it beeps when you press clear (The C button near the number 9 button). If it does not make a beep sound, you are right, it is frozen and the problem is usually either a faulty keyboard or printer (but you usually have an error code or dashes on the display if printer problem). Take it to be repaired.
If it does beep, it is not frozen and it is probably just waiting for you to finish something you started. Try pressing clear (C button near the number 9 button) in each mode and then press subtotal and then cash. So turn key to REG mode, press C SUBTOTAL CASH. Turn key to MGR mode, press C SUBTOTAL CASH and so on for each mode. If it shows an error message, please let me know which one and we can check further
May 09, 2017 | Retail Supplies
Ave tried to use the recover disk 4 times now, and
If you reinstalled the Operating System and are still getting errors then it is a hardware issue.
From what you describe it sounds like your hard drive is failing. A failing hard drive will "lose" files out of nowhere and cause many "weird" errors because the lost files are usually system files needed for Windows.
Feb 11, 2010 | Toshiba Satellite M55-S3512 Notebook
Error 60.20 hplaserjet 4250
Issue
After powering up the printer, a 60.2 error is displayed on the control panel. Even after power cycling the printer, the error does not clear. This error indicates that tray 2, and the lifter-motor for tray 2, are not functioning.
Follow the steps in the Solutions section before changing the lifter and DC Controller PCA.
Solution
Complete the following steps, testing the printer after each step to determine if the issue has been resolved:
  1. Turn the printer off and then power it back on again.
  2. If the error persists, turn the printer off.
  3. Verify that the tray 2 lifter wire-harness is fully seated in its connector on the DC controller PCA. Test the printer.
  4. Check the tension of the spring in the lifter. If the tension is not correct, replace the spring (RC1-0198-000CN). Test the printer.
  5. Replace the tray 2 lifter-driver assembly. Test the printer.
  6. Replace the DC controller PCA. Test the printer.
Jun 07, 2009 | HP LaserJet 4250dtn Printer
HP 3380 making weird sounds.
Check for blinking lights on the control panel to determine if there is an error (consult your documentation for troubleshooting)
If you cannot determine there is an actual error, reinstall the printer's drivers.
1) Unplug any connection to your computer from this device (usb wire, scsi, cat-5 cable)
2) uninstalling the drivers from the hardware menu
3) reboot your PC
4) confirm the printer is no longer installed on your PC by going to the printers section of your control panel.
5) Follow the installation proceedure ducumented for your printer.
6) restart your PC if requested, if not go to step 7
7) test that you can print to your printer.
If this does not fix your problem, contact HP support. They may have more information for you. I'm seeing alot of these HP LJ3380's today. are they all yours?
May 08, 2009 | HP LaserJet 3380 All-In-One Printer
My Dell printer 2330dn is showing an error of 900.57 Firmware - what does this mean? It will not print
clogatto,
This error identifies a problem with the printers "internal language". Many times the firmware is just outdated and needs to be updated.
Since this firmware is vital in the communication of components, outdated firmware will cause miscommunication such as error messages or weird symptoms.
I would recomend having a tech update the firmware since you really need to know what you are doing.
Apr 17, 2009 | Dell Office Equipment & Supplies
Documents are printing slanted on page
It sounds like need some technical maintenance and at that point you have two options.. take it to a service center, or buy another printer (or if whithin warranty talk to HP about your problem, your attempts to fix it and possibly get it replaced). sounds like a component inside your printer may be either not working properly or there's something inside keeping the rolling componentes from keeping the page straight as it goes through your printer.
It does not sound like a driver problem...
btw.. did you mean carriage jam or cartridge jam??
if it was carriage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00054450&lc=en&dlc=en&cc=us&rule=8331&product=303753
if it is a cartridge error try check the following:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&lc=en&dlc=en&cc=us&rule=8331&product=303753
Nov 26, 2008 | HP Photosmart 2410 All-In-One InkJet...
Mac OS10.4.11 Epson C1100
I also use a Mac, (OSX 10.3.9) does this printer show up in the list when you activate the Printer Setup Utility (PSU) Do you get any error message from the Mac such as Printing Stopped etc. What shows when you click on the PSU after clicking on print etc.
Jul 01, 2008 | Epson Aculaser C1100 Printer
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
61 people viewed this question
old marine
old marine
