Question about Maytag Neptune MAH5500B Front Load Washer
I have a ge WCVH6800J0WW front load washer and it's leaking from the bottom of the door. It's only 2 years old and I don't see any tears in the gasket. any suggestions?
    Sergeant:
    Champion:
  • 277 Answers
Could be the door is slightly warped and it is not sealing
Posted on Jul 21, 2010
I have a GE front loader washer that leaks from the bottom sometimes. It is not leaking from the inlet or drain hoses. Small weeping from bottom near the front. Are they prone to this? Does it happen...
Hi, Open the door, and with a flashlight carefully inspect the rubber boot between door and tub pulling it back. You are looking for a cut or tear at the bottom of the boot. Hope this helps.
Jan 17, 2011 | GE WSXH208A Front Load Washer
We have a 2-year old GE washer WBVH5200J3WW brought from HomeDepot. It leaks water from the bottom. Any suggestions are appreciated.
Just started having the same issue (ours will be 2 yrs old next month) we are thinking its the rubber seal tube around the front that is worn out....
Jan 16, 2011 | General Electric WBVH5200J Front Load...
Leaking like crazy and only 2 1/2 years old. Where are the screws so I can take the bottom panel off?
Their are 3 screws holding the front lower panel onto this unit.If you can tip the machine back some and put a block underneath it will help you see and remove the screws ,I believe they are 1/4 inch or t15 torx... If the unit is leaking that bad before tearing apart carefully run your hand around the lower section of the door boot (rubber) and inspect for a tear or a hole Hope this helps you out GOOD LUCK
Sep 04, 2010 | Kenmore HE2 Plus Front Load Washer
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
I have a GE front loader that leaks from the bottom, any ideas what it is from?
Is it coming from the front? You can take the bottom panel off and look inside. If the middle is not wet, it may be from a torn door gasket. Pull back the rubber seal on the machine (not the door) and you may see a big tear. That's what happened to ours. We ordered a new one on ebay and we are installing it now.
Apr 11, 2009 | GE WSXH208A Front Load Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The Washer seems to continually leak.
Remove lower front axcess panel and check where leak is. Also check door boot for any tears,holes.
Jan 16, 2008 | GE WSXH208A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
179 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
