Question about Reebok Vista Treadmill - RBTL13305
The machine powers up but the screen does not come on. i have checked all the wires and they are all attached. it is a reebock I run treadmill. please help
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Check the main harness running up to the console through the leg. unplug it and use a volt meter to test the red and black wires. You should have 9-12 vdc if you do and the console is not lighting check that the safety key is in place. If it is and it is still not coming on the console is malfunctioning and would need replaced. If there is no voltage coming through the harness then you will need to check the harness for continuity. If harness tests ok then the controller is malfunctioning and would need replaced.
Posted on Aug 11, 2010
Treadmill is receiving power but will not turn on
It sounds like you have verified power from the wall. I would also verify that the power cord is getting the power from the wall to the machine. If this tests good, continue to follow the power until it stops. By this I mean, make sure you are getting power past the on/off circuit breaker. If you are getting power past this and into the lower board, chances are the lower board is not sending power to upper board. This could be the cause of a faulty lower board or something as simple as a short in the wiring between the upper and lower board. You can check the wiring by using a multimeter to confirm continuity. The attached link is a quick guide on using a multimeter. Video about Multimeter Testing
Apr 12, 2014 | FreeMotion 775 Treadmill Exercise Machine
How do I regain lost functions on a Reebock RT 5.1 treadmill?
http://www.manualowl.com/m/Reebok/Competitor-Rt-5.1-Treadmill/Manual/350955 It's look like the engine controller has some fault occurred on it,those board made out of components,as you mentioned motor is spinning but controller not working,so might be liquid damaged through top or faulty circuit refer manual from web ,it's fixable
Mar 31, 2014 | Exercise & Fitness
Reebock treadmill bogs down
see the videos and fix it. God bless you.
lube the rollers bearing front+back , test the drive belt motor, and replace it if necessary.
Oct 14, 2013 | Reebok 8050 ES Treadmill
No power from power pack to switch display , need wiring diagram as tried with meters and no success
see the diagram attached and troubleshooting and fix it.
God bless you
However this Sympton is because you do not LUBE the deck belt do it and rollers bearings too, this will fix it.1_14_2013_9_11_01_pm.gif1_14_2013_9_11_33_pm.jpg1_14_2013_9_12_03_pm.png
Jan 14, 2013 | Hammer Walkrunner Rpe Treadmill
Irun treadmill not working- blank screen, belt not running but power light on
1) adjust the REED swtich, clean, and tigh the wires connector.
2) After you did the adjustmente RUN the software calibration for diagnose, troubleshooting, and fix it.
see the diagram attached.
Jul 03, 2012 | Reebok treadmill i-run s
Screen won't work
Dear Sir:Adjust the reed swtich see the diagram attached, clean, and tigh the connector very well. 2) Tight the ribbon cable from key pad 3) Tight the connector from display board vs lower board 4\)Measure the voltage input for treadmill must be +- 10% tolerance 5) Reset the c. breaker 6) Test the fuse inside 7) Do not use extension cord 8) Use indepent circuit for the machine 9) Try to use stabilizer voltage 10) Run the software calibration for diagnose and troubleshooting easy.
May 03, 2012 | Proform 400 CT Treadmill - Treadmills
Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
Dear Sir:
I will help you inmediately.
1) Display does not illuminate
when machine is powered
on.
Insufficient power source.
Plug treadmill into a dedicated amp circuit.
2) Loose 10 pin connection at
display console or wax/lift
control board.
Check all electrical connections for proper
attachment.
3)Damaged main harness wire
connection.
4)Replace wire harness.
Faulty display console or Wax/
Lift Board.
Verify if 8VDC is present at P1 pin, 3-4 and
12VDC at P1 pin 9.
a)If yes, replace Display Console.
b) If no, replace Wax/Lift Board. See How To...
Replace Wax/Lift PCB.
Use VOM digital (Voltimeter)
Hoping that you can resolve, if you need some extra help, please reach me.
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Life Fitness 9100 Next Generation...
Please any one can send me a Reebock, Premier Run ( RE-12301) tread mil control board Sercuit, becasue when I power up my treadmill its fuse burnt. Why is that. Please help
Dear Sir:
SOLUTION:
a. Check the reset/off circuit breaker . If the circuit breaker has tripped, wait
for five minutes and then press the switch to the reset position.
b. Make sure that the power cord is plugged in. If the power cord is plugged in, unplug it, wait for
five minutes, and then plug it back in.
c. Remove the key from the console and then reinsert it.
d. Make sure that the reset/off circuit breaker is in the reset position
e. If the treadmill still will not run, you MUST replace the complete PCB to due some electronic component is in ShortCircuit.(Reason for to blown the fuse or c.breaker.
You must provide Mark, Model,Serial Number. please contact the phone number:.CALL TOLL-FREE from the:
1-877-994-4999
www.reebokservice.com
I hope to help you. blessing , sincerely.
E.CUADRA
MANAGUA, NICARAGUA C.A.
Sep 13, 2011 | Reebok Vista Treadmill - RBTL13305
It won't start
Make sure there is power at the outlet.
Check that the breaker is set (on/off switch beside the power cord.)
Attach the magnetic safety key, the console should power up.
If not, unplug the machine from power, remove the motor cover, check that the wires are all secure. Check on the electronic motor controller fuse. If it is bad, you can replace it and try again. If it blows the fuse or breaker again, you may need a new motor controller PCB.
Dec 18, 2010 | Shopzeus.com EPIC T40 Treadmill with 68"...
Reebok Vista Treadmill - RBTL13305 Logo
161 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
