Question about Car Audio & Video
JVC KD LHX552. When you turn evey thing seems ok. but then the sound keeps going up and down. and the voice keeps going ai all langaues. even whe you turn the car off it doesnt stop. have you any ideas on how to fix this problem.?
  • 54 Answers
I sugges that you read first the instruction manual look the word trouble shooting then try to analize wich one you want to solve your problem settings. Check the wirings too.
Posted on Apr 29, 2008
  • 23 Answers
I'm not sure what you're talking about when you say "the sound keeps going up and down and the voice keeps going ai all languates..."
But as far as when you turn the car off and the unit doesn't turn off...
It sounds like you're tapped directly into the battery power and not to the vehicle's switched fuse box.
You should take at your vehicle's owner's manual and find out where the "Aux power" is located (or purchase a compatible adapter wiring harnes kit so that you can plug the cabling directly into your stock wiring harneses).
With a head unit, you don't need direct battery power (just accessory power). Only Amplifiers need a direct link to the battery through a large capacity cable. Amplifiers require the use of an "Amp Control" cable (typically blue or blue with white stripe) that tells the Amp when to shut off.
If you're tapped directly to the batter (not to "Accessory" power) then you KD LHX552 doesn't know that you've turned the ignition off. Re-routing power to an accessory (or Aux) lead in your vehicle's fuse box should fix the issue.
It might even fix you're "unexpected" performance from the device.
**Please post feedback and rate my solution if it helped you!
Lounatech
Posted on Apr 24, 2008
My jvc kd-avx33 keeps switching off while driving at first it was just the screen going off having no affect on the sound but now the whole thing seems to switch off every minute or so
I have the same problem!!! Apparently it's the connector pins one the actual stereo unclip the face and you can see the gold plating might have worn away, i've had this problem on 2 previous JVC models, costs around £50 to be repaired, but i'm trying to find the part myslef.
Here is a number if you need it:
01215226666
Feb 27, 2011 | JVC KD-AVX33 Car Video Player
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
Car stereo JVC KD-PDR40 lost manual can't set clock?
hi my jvc kd-pdr40 cd player keeps resetting the sound to basic with no bass everytime i turn it off
Sep 26, 2009 | JVC KD-PDR30 CD Player
Had this for s580 for the last 5 yrs...the other
Check for output at the rca jacks,try the radio.Unit this old may need the power amps(s),is unit used mostly at high volume?, replaced,may not be worth the cost.
Sep 07, 2009 | JVC KD-S580 CD Player
Jvc kd avx22 chamelion no subwoofer
THATS CAUSE DVD IS ,,HAS 5.1 AUDIO ,,THE OTHERS DO NOT ,,THERE IN STEREO 2,,CHANELS,,UNLESS YOU GET A PROGRAM TO CREATE THE 5.1
May 15, 2009 | JVC KD-AVX2 Car DVD Player
JVC KD-NX5000 NOT WORKING PROPERLY
I had the same problem, where the Sat radio, the bluetooth and the ipod were all non-functional. Turns out, they all go through one central hook-up, so you have to make sure that connection is good.
When mine did not show up or function, I looked at the install under the foot board of the front passenger seat that the installer did, and nothing looked out of whack. Upon closer inspection, one of the cables was had been pressed out of it's proper place and loosened enough to cause a bad connection.
I don't care for the install, but there was no problem with the equipment, so check all of your connections. Even to the point of pulling them out and reconnecting them to see if that fixes the problem.
Robert
Jul 08, 2008 | JVC KD-NX5000 Car Video Player
Kd-lh910 connect error
I Just Bought A Camaro Z28 With This Receiver/CD Player In It And It's Doing The Same Thing Also., You Would Think Someone Could Give A logical Explanation For This Problem. I Even Tried Hooking It Up Direct To The Battery And Still The Same Thing Happens. I Guess I'll Just Have To Trash It. Looked Like It Would Have Been An Awesome Player If It Would Work Right.
Mar 07, 2008 | Audio Players & Recorders
Jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Sep 01, 2007 | JVC KD-PDR30 CD Player
Car Audio & Video Logo
169 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
