Question about Canon Pixma iP4500 InkJet Printer
Waste ink tank nearly full - Canon Pixma iP4500 InkJet Printer
  • 4 more comments
  • Anonymous May 11, 2008
    waste ink near full
  • Anonymous May 21, 2008
    Message on my canon multipass mp700 inkjet printer says waste ink is near full. How can I get to the waste ink container to drain out the ink? Is it doable or do I need to take it to the canon authorized dealer?
  • yodotcom Aug 25, 2008
    Can you tell me where the waste ink tank is on the F60?
  • Anonymous Sep 09, 2008
    Where is the waste ink tank?
  • rdeel Oct 17, 2008
    where is the tank
  • frenA Dec 23, 2008
    I have a Canon imagePrograf W2200. The red light is on and the message says Rep. waste ink tank.
    President:
  • 2,351 Answers
This is not an easy job to perform but you have little choice unless you want to buy a new printer.
Glued to the top of the waste tank is a piece of foam. It is exactly the same type used to filter the air in a portable air conditioner.
US cost about $2.00. You need t replace this or ink will end up spilling into the printer. Place a rag around the tank to catch overflow. You can use a paper towel or rag to slowly push it into the tank & absorb the ink. Please go slow, the ink is thicker than fresh ink & it will not come out easily. If you can get a syringe & use it to pull ink out you'll save a ton of time. Than you can use a rag to wipe out the rest of the ink. Use alcohol to wipe the top inside of tank.
Than cut a piece of foam & super clue one side to the tank. Keep it flush with the top of the tank. (All done).
Mike
Posted on Apr 23, 2008
How to reset canon ip4500 waste ink pad full?
Posted on Nov 16, 2008
4 Suggested Answers
SOURCE: WASTE INK NEAR FULL
For Canon Multi PASS F60 Printer:
"Waste Ink Near Full" Error on LCD Display Screen
On Canon Support, the fixes are one of two things:
1. Turn of printer (holding on/off button for about 1 second) and wait approximately 10 seconds. Turn printer back on. If on/off button does not turn printer on/off, then unplug the printer.
2. If the above doesn't work, your printer may need to be fixed.
What's not said on the website: What does the error "Waste ink near full" mean.
Posted on Jun 27, 2008
  • 33 Answers
SOURCE: Waste ink near full
Here is a link that provides info about this problem. hope this helps.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=10443#SupportDetailAct
Posted on May 03, 2009
  • 52 Answers
SOURCE: The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
Posted on May 18, 2009
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Where is a waste ink i have error message says WASTE INK NEAR FULL help me on that, thanks
I have had this problem. There is a counter in your printer that must be reset to move on. The ink tank may not be full, but the counter estimates it is full (and maybe it is an instruction to you to buy a new Canon printer), and to actually empty the ink tank would be an uneconomical task. How do you do it, there are a number of helpers here so Google: MP730 waste ink near full.
Apr 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
WASTE INK TANK NEAR FULL.
see solution to INK TANK NEAR FULL SMART BASE 360
Oct 21, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Canon Pixma iP4500 InkJet Printer Logo
1,949 people viewed this question
old marine
old marine
