Canon Imageclass MF6530. Leaving heavy inch wide black streaks across right side of page. Took out toner cartridge and installed new one, same results. Also noticed what appeared to be burnt paper filament in old cartridge and new cartridge once that was installed (filament was not noticed on toner when originally installing).
    President:
  • 567 Answers
Hi it seem as if your printer is have more than one problem at the same time,with the Leaving heavy inch wide black streaks across right side of page.This usually cause by dirty print drum roller and dirty corona wire in the printer you should clean both,using the appropriate cleaning material.
Posted on Jul 21, 2010
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
THE PAPER SELECT ARE NOT COMPATABLE, SELECT LGL IS EQUAL TO 8.5/14 FLSC IS EQUAL TO 8.5 /13. TRY TO SELECT BLACK COLOR OR CLEAN YOUR DEVELOPING UNIT.
Feb 06, 2014 | Canon imageCLASS D880 All-In-One Laser...
My printer keeps printing blank papers and tells me to clean the platen glass. i've wiped it down and nothing's changed. Help!
I have a tip posted here on Fixya that addresses this very problem. Here is the content from that tip:
This tip works on all Canon Imageclass 6500 series machines including the MF6500 MF6530 MF6531 MF6540 MF6550 MF6560 MF6580 MF6590 and MF6595.
First of all if you are experiencing blank copies and or prints the best thing to do is try a different toner cartridge. In rare cases the black copies/prints CAN be caused by a defective cartridge. In MOST cases it is caused by a broken or detatched laser shutter lever or arm. When a toner cartridge is inserted and the door closed, a small plastic arm opens the laser shutter. If this arm is broken or has become disconnected then the shutter is not opened. This blocks the laser from writing the copy or print image onto the drum and this results in no print being applied to the paper. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 18, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
ImageClass 6530 copies and prints blank pages.
This is either your toner cartridge or more likely the plastic arm that opens the laser shutter is broken. When you insert a toner and close the access door, there is a plastic arm that opens the laser shutter. If this shutter does not open it blocks the laser and results in blank copies. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Mar 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
CANON MF6530 COPIER LEAVING STREAKS
Is this problem appears when you copy from ADF, but not from platen copy glass?-If Yes clean the ADFs copy glass
If the streaks appears horizontal or vertical?
Check the drum unit and/or fixing film
Jan 12, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Canon MF6530 spits out blank pages
Worn Laser Shutter Arm. Part number FC6-7331. The laser door is staying closed instead of opening to write to the drum.
Jun 24, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
What is causing black streak
You should try changing the toner cartridges first. There may be something stuck in it causing the noise and streaking
Apr 14, 2008 | Canon imageCLASS D661 Digital Printer
63 people viewed this question
k24674
Marvin
Marvin
