Question about Maytag MAH6700AWW Neptune Front-Load Washer
By mistake I pressed the ControlLock button instead of the power button. I cannot get the control lock button to release and turn off now. How can I get the Control lock button to turn off?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 22, 2010
How do I unlock my projector TLP-XE30 I pushed the lock button by mistake. and now I cant even turn it on.
to release the key lock, set the [Key Lock] to [Off] using remote control. Pressing the [RETURN] button on the projector for 10 seconds also sets the [Key Lock] to [Off]
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
have a nice day!
Jerry,Lampdeng Limited
Feb 12, 2014 | Toshiba TLP XE30 diamond lamp
Code for sanyo plasma screen(50") hdmi.
1. PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
3. ENTER 9-9-1 (two blinks on the remote)
4. ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button
until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press
this sequences of buttons up to 100 times to search the entire library of codes.
5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for
your device.
Mar 28, 2010 | One For All URC-4605 Remote Control
Cartridge is not recognize, it states that my cartridge is not installed properly, i already tried to removed it and reinstall it but always the same result.. help pls
1. Switch off the printer (the button Power ).
2. Holding button Resume , include the printer (press the button Power ).
3. Holding button Power , release button Resume (indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (indicator of the feeding/readiness green, indicator mistake yellow)
- after buttons will be отпущены, indicator of the feeding/readiness certain time will twinkle green (time моргания depends on models of the printer), then green fires constantly
- if after these action instead of constantly burning green printer continues to show the mistake, that or you mistakenned in points 1 4 (switch off the printer and repeat with point 1), or beside printer additional mistake, which necessary to avoid, otherwise he will not fall into service mode (that means this mistake possible hear here).
5. Four times press the button Resume (under each striking the button Resume indicator of the feeding/readiness changes the colour, but beside printer, having more one indicator indication is switched: readiness/ mistake).
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times contract.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6:
# For printer iP2000 and iP6220d
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again.
# For printer iP3300, 6210d, pro9000, pro9500
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant of the unset)
Sep 30, 2009 | Canon PIXMA iP1300 Printer
Canon doc 203 both light blinking
or
Sep 30, 2009 | Canon Office Equipment & Supplies
I cant print with my canon ip1300 printer? why?
or
Sep 28, 2009 | Office Equipment & Supplies
Need codes for zenith tv
www.rockabilly.net/files/manuals/URC-3220.pdf
Jun 04, 2009 | One For All URC4220 Remote Control
Need code for zenith on urc-3220
016,017,092,000,[COMBO--000,037] are the codes
for your Zenith TV. Follow these instructions
carefully. These are as close as i can get you
to getting you operations...the rest is up to
you. GOOD LUCK!
  3. ENTER the 3 digit code for your brand.
  4. You should receive 2 quick flashes after entering your code.
  5. PRESS the POWER button to test the code.
If you have tried all of the set-up codes for your brand of equipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
  1. PRESS the button for device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  4. ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
Blinking Back the Code:
  1. PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
  3. PRESS 9 - 9 - 0.
  4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
  5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
  6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
Mar 03, 2009 | RCA Universal Remote Control
Need info on urc-3220
you. GOOD LUCK!
  3. PRESS 9 - 9 - 0.
Dec 31, 2008 | One For All URC-3021 Remote Control
Flashing lights
3. Holding button Power , release the button Resume (the indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press the button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (the indicator of the feeding/readiness green, indicator mistake yellow)
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press else raz.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times podryad.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6 :
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press else raz.
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant sb
Apr 02, 2008 | Office Equipment & Supplies
Philips univeral remote CL034
Hi, OK, I seem to have found a solution to this....I have a Magnavox CL035 (I think it's the european version of the CL034). Here's how I programmed it:
1. Turn on the TV (or whatever instrument you want to program).
2. Hold the Code Search button until the red light remains on.
3. Press and release the TV (or whatever instrument you want to program) button.
4. Now, patiently(!) press and release the power button. (I repeatedly made the mistake of doing this too quickly so take your time!
5. When the TV turns off, press the enter button (-/--).
Should now be working!
Feb 22, 2008 | Televison & Video
Maytag MAH6700AWW Neptune Front-Load Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
