Question about Vacuums
I am trying to take my philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the life of me find how the wheel end comes apart. any tips?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Generic problem for all Vacuums
I am trying to take
I am trying to take my Philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the life of me find how the wheel end comes apart. Any tips?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe the part you are taking about is the fan and the fans generally are installed by a reverse thread and screws off counter clock wise. Once you removed the fan or the wheel you can use a blower and blow the motor clean, remove the carbon brushes and use a pipe cleaner to clean out the carbon brush holders and then re-install. Also free to contact your local vacuum cleaner dealer in your area or in the yellow pages under vacuums.
Posted on Apr 22, 2008
I started vacuuming and the vacuum motor slowed down, then stopped. I smelled a burning smell. Then I discovered the next day that the bag bottom was wet and falling apart. Sebo X4 model
sucked up liquid goes with the air through the motor
that would cause the motor to burn out
with the current low cost of new vacuums , the repair /replacement of the motor would be close to a new unit
take it to an appliance repair shop and get a proper diagnosis and quote
Dec 02, 2016 | Vacuums
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
I turn it on and nothing happens,
I would double-check the seating of the bag. Some machines have a lockout switch that keeps you from running the vac with a bag incorrectly installed (which would then suck dirt into the motor).
Mar 16, 2014 | Simplicity Type S Sport Vacuum Cleaner...
My dyson dc11 has just stopped after sucking space saver bags
Hi Philip,
Your DC11 is equipped with a safety device which shuts the cleaner down if it starts to overheat. It's likely that this is what occurred, as there may not have been enough airflow through the cleaner to keep the motor cool. If you unplug the cleaner and leave it to cool down for at least an hour, you should find it will work again.
If the cleaner still won't run after this time, get in touch with us directly so we can provide further assistance - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 31, 2011 | Dyson DC11 All Floors Bagless Canister...
Dyson cylinder i was sucking a vacuum space saver bag and my vacuum just stopped
Hi Philip,
Kind regards,
Jack
Electrolux vacuum cleaner 1500W motor diagram neededbecause it is not sucking enough
if motor is turning than it's not the motor......check for other more than likely faults such as.......restricted or kinked hoses......obstructed hoses,......clogged vents both intake and output sides.......clogged heppa filters on the output side...after the motor if it has one......restricted or obstructed intake air vents where the motor sucks air in........clogged bags if it uses bags.....in any case, you have something either blocking or restricting the suction side or something restricting the air output side.........if all is well and you see no blockages, then and only then should you suspect the motor.
Nov 27, 2009 | Electrolux Vacuums
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Sebo Automatic X1 vacuum cleaner doesn't produce much suction.
If the motor really is working, the problem is most likely to be that there's a blockage somewhere, and on this excellent vacuum cleaner there aren't too many places to look. You've probably already looked in the inspection flap on the underside. If not, that's the first place to look. Next is to separate the bag compartment from the base of the machine (press and hold the button at bottom front of bag compartment and just pull the two sections apart - if this hasn't been done for some time, a gentle levering with something like the plastic handle of a dish brush can help). Then look down the rearmost vacuum tube to check that it's clear, also make sure the little sieve on the other tube is clear. That's all for the base section. Now open the bag compartment, remove the bag and check that tube all the way through the hose.
Another possibility is air leakage, and it does happen on older machines that the plastic tube onto which the attachments fit becomes so worn that it no longer seals properly in the hole in the base (where it lives for normal floor vacuuming).  You could also have split in the flexible hose, of course.
If none of this reveals a problem, the motor probably isn't as healthy as you think it is.
I hope this helps. Any questions, just post again and I'll see what more I can do.  I value your feedback, so please rate this response.
May 04, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuum cleaner by bosch
The store you bought your vac from should have bags for it. Alot of stores and Sew and Vac stores carry a large variety of bags, you will have to shop or call around. A repair shop should be able to order them if need be. You should change bags when they are maybe 3/4 full. The fuller they get, the suction will decrease and make the motor have to work too hard. Also check your filters, change them if they look bad.
Mar 24, 2008 | Bosch BSG81313UC Premium Bagged Canister...
Vacuums Logo
156 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
