Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Won't start Try to put on dishwasher. just beeps. doesn't start. bottom drawer works fine.
  • Fisher and P... Master
  • 3,247 Answers
Most likely the door close sensor is not able to determine the drawer has been shut. Either the drawer has come off the rails or the sensor is faulty. The other possibility is the door seal (located at the top of the housing is out of place and is preventing the door from closing.
Best option is to get the drawer out from the housing and inspect the door seal. To get the drawer out refer to page 7 (step 2) in the installation manual.
Let me know if you want to fix this yourself or get a technician. It requires a bit of familiarity with electrical repairs.
Please rate the solution so that we know if it was of help.
Posted on Jul 25, 2010
Fisher & Paykel dishdrawers - no power at all to the top drawer
Try and do a power reset to the dishwasher. This means turn the mains power off to the dishwasher and back on again. If there is no mains socket under the kitchen bench then maybe do this from the mains contactor switch in the meter box. If there is no difference to the behaviour of the top drawer then the controller has most likely packed up. You can test things out by taking controller from bottom drawer and putting in top drawer. But this requires some experience with taking out the front covers of the drawers, taking out the connectors and putting back. If you mix the connector connections etc you can cause more damage. Take photos as you go along. Make sure the dishwasher is disconnected from mains power when you are working on it.
Feb 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
No power top drawer
Try to reset your dish washer. Turn off main power supply and leave it for at least 1 min. Is there any error code appear/beeping sound?
Sep 09, 2007 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishdrawer: Does not start, just beeps once
Some sensors on the unit are telling the controller there is a fault.
Most likely the sensor checking the drawer is open or close is giving a fault. It is likely the drawer has come off the rail.
May 22, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
The top dish drawer turns on but won't go. It comes up with a little clock and counts up to about 11 or 12 then goes off. It continunally beeps and won't actually start up.
Somehow your drawer was put into a showroom mode. In this model, with the power off, push ECO and Power button for 5 seconds. (ECO first then Power and hold for 5 seconds) this should clear this out.
If you still have issues seen me another message and I will respond as quick as possible. Taking my daughter out to a party tonight.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 27, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw on our dishwasher isnt working .bottoms fine.wont start just beeps and the numbers /display is jumbled
If this has stopped working suddenly then most likely the controller on the top drawer has packed up. Before panicking, take a clean moist kitchen wipe and clean the edges inside around the drawer including the touch buttons inside. Sometimes the grime confuses the controller. Best of luck.
Oct 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Dec 31, 2008 | Fisher DS603W / DS603B / DS603I Dishwasher
Dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Jan 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
128 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
