PCI card I recently bought a pci card for desktop, fitted card to desktop no probs and it recognised wireless network in house but cannot log onto the internet
    Problem Solver:
  • 9 Answers
Make sure you have any appropiate software installed and that you are using the correct wireless authentication method (WEP/WPA ect...)
Also check to make sure there is not IP Conflict between your PC and another wireless device on the network.
You can also try assiging your PC a IP Address to use within the gateway address, or set it to obtain it automatically.
exact instructions to do this all depend on your operating system and the wireless connection utility used.
Hope this helps
Anthony Kinson
Posted on Apr 22, 2008
I am currently using a wireless 'dongle' to connect to the internet but I feel that it would probably give me a more stable connection if I had a wireless card. Can anyone give me details of
Hi Lynda,
The best option for you would be to purchase a wireless PCI network card.
They are relatively inexpensive and should have a stronger signal over a longer distance than a wireless USB dongle.
Below is a typical wireless network card and it should be freely available from your local PC store
I have included a brief explanation for your convenience:
A PCI wireless adapter card connects to a desktop computer's PCI bus. Because the PCI bus is contained inside the computer, the unit must be opened and the wireless network adapter installed inside.
An example of a PCI wireless adapter card, the Linksys WMP54G is shown above. This unit is more than 8 inches (200 mm) long in order to accommodate the standard connection strip required to electrically join to the bus. The unit attaches and fits snugly inside the PCI, although the wireless adapter card antenna protrudes out the back of the computer
Best wishes,
Graemevm
Jan 24, 2012 | QDI Group QDI KuDoz 7 Motherboard
Can this PC be converted to wireless? If so how? House has wireless thru AT&T. The original ethernet connect portal died. Already jerrymandered a second portal and that has now also gone dead.
The only way for making it wireless is buying a wireless network card/adapter that can be installed in your Desktop. You should look for a PCI/PCI Express Wireless Network Adapter.
May 26, 2011 | Acer Aspire X1200-B1601A PC Desktop
Compaq Presario 5220 Desktop Windows 98 internet: Dial-up Can a DSL card be installed or would I need to go with a wireless USB? And would wireless USB work on Win98?
You can install a network card inside the computer. You will need a PCI or an ISA card. (I know PCI network cards are easy to find at most of the computer shops.) See this site for how to install a card: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07111&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=93139 . However you should open your computer and check the space between the devices in the slots in the computer. There is an AGP slot with a video graphics card, 1 PCI/ISA slot with a modem (default specs), one free ISA slot and one free PCI slot. However depending on the graphics card one of these slots may be blocked by the card. You'll either need to get a card that fits the available slot or remove the modem and use that slot.
Here are some PCI 10/100 network cards: http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=587&name=10-100%20Ethernet%20PCI/ISA . Most of these are compatible with Win98. I'm not sure if there are any gigabit NIC with Win98 drivers.
Wired and wireless USB NIC adapters exist. However, you will be limited to the USB speed. If you have USB 1.1, that will be really slow. Most likely your computer will require a reboot anytime the connection is lost.
I hope this helps.
(who recently removed an internal modem to put in a PCI gigabit card in a newer desktop than yours. The procedure was straightforward and improved network performance in the household immensely. The failing on-board NIC was tying up the router for everyone.)
May 12, 2011 | Compaq Presario 5220 (388098-003) PC...
I bought a DELL optiplex 745-small form in Japan a couple of years back (Service Tag is HXXR8BX)and always used the pc with a LAN cable. Now I was tranferred to the netherlands and the house I live has a...
Below you will find 2 options to add wireless connectivity to your desktop.
A. USB Wireless LAN
http://accessories.us.dell.com/sna/category.aspx?c=us&l=en&s=dhs&cs=19&category_id=6638&nf=44907%7e0%7e598274&sort=-ratingaverage&~ck=anav
This is the easiest solution to add a wireless connection. Simply connect the USB adapter, install the software it comes with and connect to the wifi signal, once configured.
B. PCI/PCI-e Hardware Wireless LAN
http://accessories.us.dell.com/sna/category.aspx?c=us&l=en&s=dhs&cs=19&category_id=5821&nf=44907~0~598274&sort=price&~ck=anav
Adding a PCi/PCI-e expansion card requires opening your computer and manually installing the card, then installing the driver/software and configuring the wireless access. These cards typically offer faster speeds and stronger radios to communicate with wifi signals better.
NOTE: There are 2 types of wireless cards in the second link: PCI/PCI-e and Half-Card/Mini-Card. Half/Mini-Card adapters are for laptops only - they will not work on desktop computers!
Both USB or PCI/PCI-e offer excellent solutions to getting wireless access from your desktop. Furthermore, since it can be purchased through Dell.com, they can ship anywhere worldwide, so delivery to the Netherlands should not be a problem.
If you have any questions, you can always contact Dell's Customer Support by telephone and be sure to give them your service tag number, that will ensure that you get only the parts that match your desktop.
Aug 14, 2010 | Dell OPTIPLEX 745 PC Desktop
Wireless network card for dell dimension c521
a standard pci, or pci-express card will work...or you can always go usb
Jul 22, 2010 | Dell Dimension C521 PC Desktop
I purchased an HP A4327C desktop computer and wanted to convert it to wireless. I purchased a Level One11g Wireless PCI card and the card will not fit into the slot inside of the computer. Is it the wrong...
HI,
On your computers motherboard, you have three slots
  • PCI slot
  • 1 PCI express slot 16
  • 2 PCI express slot 1
You would require a PCI express 1 ex wireless card for the system
Thanks
Proton
May 11, 2010 | HP (EA118AA) 802.11a/g/b Wireless Adapter
ATI Radeon 9250 PCI card not recognised.
Make sure the slot isn't disabled either by jumper settings or in the bios, and the card is securely inserted in the slot. If these aren't the case, you have yourself a bad card, or a bad slot.
Apr 30, 2009 | HP Compaq d530 SFF PC Desktop
Need pci Filler For WMP54G OptiPlex GX150 PC Desktop
By PCI Filler I Mean The Metal Peice That Screws onto the card that screw it to the case as the Dell OptiPlex GX150
Is Very Small And The Pci Card Slot Covers Are Different Size Than A Full Size Case
Nov 05, 2008 | Dell OptiPlex GX150 PC Desktop
IBM R40 2722 1802 Error Message
This is due to the fact that IBM laptops have a list of accepted devices, and the pci card is not recognised in the list. On IBM - Amilo, Mini PCI card slot is usually at the back of computer. Locate and remove Mini PCI wireless card, you will not have integrated wireless after this.
Other solution is to find the option to disable mini PCI in bios settings.
Here is how mini pci wireless card looks like:
May 28, 2008 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
