Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Re: Sharp 32" lcd tv mod. # LC-32D44U. TV doesnot turn on .Green led light flashes constantly. Nothing else happens when I try to turn it on by remote or by on button on tv. I opened back of unit and measured voltages on the power supply board. The only voltage comming out of power board is 5 v. Any solutions? Thanks.
  • Sharp Master
  • 11,800 Answers
There should have been also a 45 volts for the CCFL tubes and 30 volts for the audio amplifiers and the tuner coming from one line and 12 volts for all the other electronics coming from a second. If none of these are present then there has been a massive failure in the source. Start checking for the origin of the failure; the most likely cause is in the power source itself (bad filtering capacitor are notorious for causing total failures like that) then test the consumers for shorts or by simply disconnecting them one at a time.
Posted on Jul 21, 2010
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
When I turn on my TV sharp model LC-32D44U turn on a 2 second on analog canal 2 than turn off and start a green led flashing ..
common problem for this particular model, one or more CCFL (backlight lams) falure. Lamps are not avalable as the replacement parts, only way to get them is to take appart bad/broken screen tv.
Oct 12, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Green lights flasghing, no picture
Tries unplug,replug tries on/off for awhile might work,not than the backlight board it dead.
Sep 22, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
TV not coming on
return it you have 14 days
Sep 19, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos 32 wont turn on
I called up Sharp, and if you are a part of Sharp AQUOS Advantage Program you get free in home service.
They were very nice about it, and I already have a technician coming to my house on Saturday and I called on Wednesday.
I doubt Sharp's policy alot less now!
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My sharp aquos 32' LCD has a heavy green tint to it. I tried reseting the settings back to factory settings, but it didn't help.
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Aug 19, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
119 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
