Question about Camco Battery Fridge Refridgerator Alarm Rv Motorhome
Bottle holder broken in the middle in my refridgerator
Can anyone suggest the best glue to attach the broken bottle holder so that i can save my rental penalty charges over the breakage. Thanks in advance for good ideas.
    President:
  • 676 Answers
Try JB weld.
Posted on Jul 27, 2010
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
We have a Back To Basics popcorn popper that has a broken piece. The piece is the clear see-through plastic top. Where can we find a new piece?
West Bend took over this company and no longer provides plastic window replacements. I fixed mine by super gluing the window and attaching a small strip of wood on top of the 2 plastic window pieces with small bolts (super glue pieces so wood can be properly attached because glue alone will not hold up to the heat). Not attractive but it works. (West Bend rep told me windows break because of high heat, but I only used mine over medium heat; I think they break at the spot where the raised lid hits the gear mechanism holder.)
Dec 11, 2011 | Back to Basics Popcorn Popper (PC6)...
Rubber holder that goes over the ear has broken. Can it be replaced and how? Bluetooth still works find.
Hi cptpatterson,
  • If you have the rubber holder broken , then you can stick it carefully with superglue and it should work fine, but make sure that the glue does not go in the ear piece which can affect the ear piece and would not work properly.
  • There are spare rubber holders available at an authorized Nokia Shop from where you can get it , but I would suggest if you want to save money you can just use super glue in small quantity and use it at the broken surface and it will work find for you as this device does not need a huge amount of strength that it has to bear.
Hope that helps..:) Let me know in case you have any queries, your feedback would be appreciated.
Sep 12, 2011 | Nokia BH-200 Wireless Headset
What is the rod at the back of the oven for, and if one of the holders comes off and is put back on is there any problems?
The rod at the back of the oven is the Thermostat probe. As long as you can re-attach the holder in the same place it's broken off, it wont cause any problem. It's simply a holder but needs to be in the right place so that the thermostat is in the right place in relation to the oven element.
You best bet is to weld the holder back on if possible. Otherwise you're going to have to find some glue rated for very high temperatures.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | GE JGRP17 Gas Single Oven
Cannot attach wand after attaching the detergent holder
put the detergent holder on the end of the wand handle.take off the first section,and put bottle into that hole.my Nilfisk waterblaster is the same
Jul 05, 2010 | McCulloch FH140A Electric Pressure Washer
Gluing the mirror back on the mount
A better solution would be to buy a commercially available mirror holder and mount this in the bottom. On these the mirror is held on the edge by clips --
http://www.amateurtelescopemaker.com/cp.htm
Jun 27, 2009 | Orion SkyQuest XT12 Classic Dobsonian...
Want to replace rear veiw mirror in 98 ford taurus
There should be a screw that will attach mirror to the holding plate. The holding plate is attached with a special mirror adhesive. You can place new mirror over the origional holder. There isn't really any way to remove the original holder without cracking the windshield
May 22, 2009 | Ford Taurus Cars & Trucks
The tabs that hold hub inserts bave broken off several of my wheels. New ones are very expensive.Has anyone figured out a way to repair so they'll remain attached to the main part of the wheel cover?
you can maybe use some sort of epoxy to glue it back together but that is only going to be temporary, i would suggest, if you dont want to pay steep dealer prices, simply go to a junk yard.
May 05, 2009 | 1999 Buick Riviera
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
CD lid
I strongly suggest super glue. Just allow the hinge to move into the opened position without the lid attached and then carefully match up the broken section and allow the glue to dry. Should work just fine. A replacement would not only be nearly impossible to find but would probably cost as much in product and shipping as the unit itself is worth.
Best of luck!
Sean
Sep 01, 2008 | Spectra Hello Kitty KT2028...
Replacement for broken paper roll holder
There are universal glue on paper holders available email upstateos@adelphia.net
Feb 13, 2008 | Canon P23-DH Calculator
Camco Battery Fridge Refridgerator Alarm Rv Motorhome Logo
83 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
