Question about Frigidaire FAC126P1 wall/window Air Conditioner
My window unit airconditioner is shaking. It
My window unit airconditioner is shaking. It appears that the fan blade is shaking which is making the whole unit shake and make noise. it is less than a year old and has only been used about 100 hours or so.
  • Frigidaire Master
  • 43,501 Answers
Unfortunately the fan blade is probably coming apart...These are a pain to replace if you can get the part...
Seems like you are looking at buying another or trying to call the customer service number of the Co. that made your unit and crying till they give you a new one...tell then you will tell everyone you know not to ever buy one of their products...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 22, 2010
Dometic caravan rooftop airconditioner fan is making a loud ticking noise
remove the cover off a/c on roof. should be able to see if fan blade or squirrel cage are hitting anywhere while running.
Jan 04, 2014 | Dometic Heating & Cooling
AOU12RLS outside unit is knocking or ticking? Any idea what it might be? Nothing appears to be in fan after taking cover off to examine.
need to check and make sure the condensing fan ( outdoor unit fan) wires are not hitting the fan blade, it could also be that the fan blade needs to be balanced.
Oct 21, 2013 | Fujitsu "AOU12RLS 12,000 BTU Cool/16,000...
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
I have a 1400 btu portable air conditioner ( AMANA ) and the fan is broken, how to replace it.
Obviously, you will have to disassemble part of the cabinet to access the fan blade. Removig the blade should not be difficult. If it's the fan motor, than that may be a challenge. However, since you did not furnish the Model Number of your AC Unit, there's not much more I can tell you, other than where to find the part(s) you'll need. Try Factory Appliance Parts http://www.appliancefactoryparts.com/airconditioners/amana/amana-motors-and-blades.html You'll definitely need the correct Model Number of your unit, to search for the part(s) you'll need.
Hope this helped you.
Jun 27, 2011 | Amana Portable Air Conditioner
How do I fix my fan from shaking so badly?
Did you just clean the fan? If while cleaning, you bent a fan blade, even a hair it will shake. Blades are perfectly balanced. Moving one just a hair, will cause the fan to shake. Trying to re=balance the blade(s) is futile, you can get it close, but it will take somr patience. If the fan has built up dust on the blade(s) will begin to shake if some blew off unevenly
Oct 07, 2010 | Lasko High Velocity Space-Saving Blower...
All of a sudden the airconditioner started filling up with water and the fan blades started spraying water out of where the air comes out. The unit is draining from the back.
Try cleaning out from under The evaporator (front) coils towards the back so the water can drain underneath the front coils towards the back
Make sure the unit is tilted a little towards the back
Clean drain hole in back too.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 23, 2010 | Kenmore 75050 Wall/Window Air Conditioner
Window a/c
first un plug the unit and then pull it out and check both fan blades for any trash or dust build up on fins this will make your unit shake
Apr 14, 2010 | Heating & Cooling
Carrier central air unit is shaking and broke a fan blade off inside the unit
TURN IT OFF! You're gonna need a new fan blade! Motor MAY be ok, and hopefully nothing was damaged by the flying blade. Just happens but not often - you're just lucky.
Sep 07, 2009 | Heating & Cooling
Fan making noise squeeking etc
ok not sure which fan or country your in but here in Australia if its the out door fan, should not cost more than $1200  if its the indoor roughly the same depending on access , may cost a bit more for labour but ... ok fan only cost indoor $600 outdoor $450 to $800 depending on weather the fan blade is seized or not, if its seized then a new blade can set you back To the $800 buck mark including the motor
May 11, 2009 | Goodman CLQ36AR49 Air Conditioner
Help me fixe my ceiling fans
Start over again!
Make sure that the HANGER BRACKET is properly and securely attached to the ceiling joists.
Then make sure that the HANGER BALL of the fixture is properly seated in the HANGER BRACKET.
Make sure the SUPPORT PIN is properly seated in the grooves in the top of the hanger ball.
Make sure that ALL the BLADES are firmly SECURED with TIGHT screws both at the BLADE ARMS AND at the MOTOR.
Remove the BALANCING WEIGHTS from the blades.
Make sure that the DOWN-ROD is indeed VERTICAL and not BINDING.
Turn on the fan in the SLOW mode and let it operate for a few minutes. Is the "shake and noise" issue still present? If NOT, turn it to 'medium speed and if still no problem turn it to high speed.
However, If the problem is STILL present, turn the fan OFF. Look closely and carefully at the LEVEL of the blades. You should be able to determine if one or more of the blades appears to be out of level. Use the minimum amount of balancing weight on the blades, and not every blade may need a weight. You do not want to contribute to the problem here.
If, after you have gone through all of the steps suggested here, the problem persists, then you have done about all you can do as a consumer to make this fan operate satisfactorily.
DOCUMENT the actions you have taken in an effort to remedy the issue on your own.
At this point load it up and return it to the place you purchased it for replacement or refund.
Good luck. :)
Mar 22, 2009 | Hunter 23852 Classic Original Ceiling Fan
Frigidaire FAC126P1 wall/window Air Conditioner Logo
676 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
