Question about Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D - Camera froze a couple of times, then when I tried to re-boot there is no sign of life. I have checked the battery, SD card and lens sensor. Still no joy. Any ideas
    Guru:
  • Canon Master
  • 1,705 Answers
A couple of thoughts, may or may not work.
1) Go to the Canon web site, see if there's a firmware upgrade to download and install.
2) See if there's a forum on the website, people may have had and resolved the same problem.
3) Ask their techs via the contact us link, see if they can help.
Posted on Jul 21, 2010
Tokina canon eos 350D error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 350d service manual link:
http://goo.gl/ELh523
it will help you to save a lot of money
Hope it helps, Thanks
Apr 08, 2013 | Tokina AT-X 124 PRO DX Lens for Canon
My Canon EOS Rebel XT 350d will not autofocus.
Sound like a broken ribbon cable in the lens. Needs to be replaced but get a quote as it may be cheaper to replace the lens with a secondhand one.
Mar 14, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Hello hemantp. This error code in this model indicates that the lens electrical contacts are dirty or slightly oxidized. To clean them you will need a common pencil with a clean eraser on the end and a lens cloth.
Detach the lens from the camera and hold it so that the lens' gold contacts are pointing down. Lightly "erase" their exposed surfaces and then clean them with the lens cloth to remove any debris.
Do the same with the gold contacts inside the camera body. Although this is a wee bit more challenging, you can do it by holding the camera so that the lens opening points down. That way no debris will fall inside as you clean. Joe
Nov 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Busy is on my screen and camera has froze
The easiest solution, and it worked for me the one time it happened was to remove the battery, let it sit. Reinstall the battery after a few minutes and try it again. make sure the battery is fresh.
Nov 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 - how can I check if it's the CF card, the lens or the battery?
eliminate....
try the cf card in a card reader / another camera / the local photo printshop
try another lens from a friends rebel or pretend to be looking for a new lens at the local camera shop
the battery can be tested with a digital multimeter @ radioshack or maplins electronic shop
good luck
rate if helpful
Oct 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D
I don't have a 350D, and don't have a list of codes but I would guess the error code refers to the Compact Flash card. In the instructions to my camera, a 400D, the solution is to remove and reinstall the card, if there is still a problem, you might have to format the card. Hopefully this will help!
Sep 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
313 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
