Question about Saws
How do i get the old blade off on the 190mm pro sliding compound saw
  • 2,176 Answers
The blade bolt should be left hand thread, lower the guard plate and then push the spindle lock and remove blade.
Posted on Jul 21, 2010
Makita slide compound- Saw Blade. LS0714
It seems as though the original blade was fitted without a spacer. These usually come with any new blade. It is simply a washer (usually aluminium) that fits in the hole of the saw blade and reduces the hole diameter down to the size of the flange on your saw. This is common practice. Never try and centre a blade without the correct size hole to flange size. Very dangerous. These washes are really cheap and can be obtained from most hardware stores. Usually in an assortment of different outside and inside diameters to suit any circumstance. Hope this helps, cheers Bob.
Oct 26, 2016 | Makita Saws
How do you adjust the laser from side to side on a Kobalt 10-in 15 Amp Slide Compound Laser Miter Saw
goto https://www.lowes.com/pd/Kobalt-10-in-15-Amp-Single-Bevel-Sliding-Laser-Compound-Miter-Saw/3512785 and scroll down to guides and documents download PDF
Dec 22, 2017 | Measuring Tools & Sensors
Blade stops in middle of cut, slipping motor rpm is un changed. 10" compound sliding Bosch miter saw
Going on the information aas I read it, the blade is slipping, meaning that it is not tightened enough or a spacer in the hole in the blade is too thick. Make sure that the wall plug is pulled out before attempting any work on the blade.
Jan 16, 2011 | Bosch 10" Slide Miter Saw
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
Jul 26, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Need to calibrate my dw708 sliding compound miter saw. How to adjust the slides for a true cut. The blade is square.
i use a framing square off of the back fence with the blade down. when it is square, i check the other side of the fence and loosen the screws on the plate with the degree increments and set it to zero
Nov 21, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Wobely blade
sounds like the bearing is going out on the blade shaft
Feb 10, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Saws Logo
48 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
