Question about Philips 47PFL7403D 47 in. LCD TV
R5 Resistor blown. Cannot find specs, or where to
R5 Resistor blown on power board. Cannot find specs, or where to get the replacement. Need to know the part & where to get it. Please help.
  • 11,361 Answers
Is it the surface mounted resistor? Pictures will help. budmrtn@aol.com
Posted on Jul 22, 2010
  • Philips Master
  • 8,457 Answers
U still can make out the resistor colors codes?Tries websites like Ebay.com,Amazon.com or might just go down to Radio Shack,have that toterance of that resistor to buy.
Posted on Jul 21, 2010
The treadmill have dcmd67 control board I need to know what value resistor R 19 have
I can't help you (directly) with the resistor value, but be aware that if it exploded, there is probably another bad component (such as a capacitor, transistor, and/or an SCR). Replacing only the resistor may result in the same problem, or may not even work at all due to another bad component. If you do find out the value, try putting in a resistor of the same value, but with a higher wattage rating. I once had a washing machine in which the model had a known problem with circuit boards blowing. I solved it by replacing a bad transistor and installing a higher wattage resistor that had blown up like yours. It never failed again. The way I found the value of the blown resistor is, I looked up a replacement board online, then magnified the photo, and looked at the color code on that same resistor in the photo. How I found the bad transistor is too complicated to explain in few words, but you can google the procedure. (You'll need a multi-meter at the very least; preferably _with_ a built in transistor checker. However, a _totally_ blown transistor can be found with only the resistance settings on a regular multi-meter).
Best of luck...
Apr 05, 2016 | Exercise & Fitness
Power supply card PLHL-T722A, 2300KEG033A-F, had a blown fuse F101 (T1AH250VP). Replaced fuse with T1AL250V. Plugged tv into wall, and resistor R5 lit up and started smoking. Thus pulled plug out...
We sell a repair kit for this board, which has the fuse, resistor and the IC that usually fails along with them.
You can find it at http://www.coppelltvrepair.com .
I've seen that board fail in at least three different ways, though, and this is the least bothersome of them.
We offer a repair service and have about 90% success even with burned boards. You don't pay any service fees if we can't fix the board.
Finally, when available we also sell boards ready for use with a trade-in option. That ends up a little more costly than a repair, though.
Sep 03, 2013 | Philips 47PFL3603D LCD TV
Bosch al 1115 cv
what values from what? would you specify, what resistor are?
God bless you
Jul 23, 2013 | Motorcycles
Blown capacitor but....
Be sure you replaced the capacitor in the proper (+) (-) orientation. There is a half moon shape line on the board on one side of the capacitor legs, that is the negative terminal. If incorrectly installed it will not work.
Jul 06, 2009 | Panasonic SC-HT1500 System
Resistor burnt up, inable to identify due to skorched bands
I have the same exact problem in a 12 volt Lincoln battery charger. Burned resistor in R5.
May 07, 2009 | Lincoln 14.4 Volt Cordless Grease Gun,...
RCA L42WD22
3 watts metal oxide resistor. Don't have to worry about volts. Just use a 3 watt
Apr 03, 2009 | RCA 20F511T TV
Blown resistor
if you mhave the circut diagram please check it .
Nov 23, 2008 | Electronics - Others
Need to know the value of a resistor
Tim, I am a commercial hvac, refrigeration, and commercial kitchen equipment mechanic. I have rebuilt many of those units. While the notion that all it might be is a 20 cent resister is noble, you are forgetting that this particular circuit has been in service in airborn oil, dust, moisture, spices AND MORE THAT attack ELECTRICAL/ELECTRONIC/COMPUTERIZED equipment.
After many years of repairing vrs replacing, the failure rate was so high in other components and circuits that I realized it just wasn't worth it. Its NOT JUST THE COST OF SERVICE AND PARTS, but also THE DOWNTIME AND LOST SALES you need to take into consideration as well.
Take it from a professional, REPLACE THE BOARD!!!
Nov 11, 2008 | Frymaster Dean MJH50-SD Deep Fryer
Resistor on power supply board
Dear Biigjohn, First, first C613 means that it is a capacitor, not a resistor.And It seems to be a electrolytic Capacitor.If it has burst, then it's can will be inside. just search. the details of the Capacitor will be on it. most likely it will be a 10mfd 160V capacitor. Check and replace.
Aug 14, 2006 | Sony KV-27V26 27" TV
Philips 47PFL7403D 47 in. LCD TV Logo
296 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
