Nikon D90 Digital Camera with 18-105mm lens Logo
Posted on Jul 21, 2010
I have a Nikon D90 with the 18-105 lens. Frequently, when attempting to take a photo, I will get an error message. If I turn the camera off and then on again the error message will go away. Any suggestions??
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
460
Points
This is a common problem with D-90's. Nikon won't admit a problem, until they do not much can be done. I have to pull the battery to make my error message go away! I know this info doesn't help much, but your certainly not alone!
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Nikon D80 error
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
When I turn on My nikon d80 with 55-300lense it shows an error
Error message on nikon d80
2answers
I have a nikon d90,when i pressed shutter button ,it is giving err message then i press second time it is not giving err message but not taking the photo.
This is an indication that the camera is not "talking" to the lens correctly. When you press the shutter button, the camera tries to focus, set light levels, and then shoot the picture. If it can't focus or set F-stop and shutter speed, then it can't shoot the picture and gives you the error indication. SO
1. You need to make sure the lens is an automatic lens capable of working with the D90. 2. You can take the lens off and back onto the camera a few times in case its a dirty contact issue or just didn't seat correctly. 3. Set the D90 to manual and make sure you move the AF selector on the front to M. Then you would manually adjust all the settings. That should take the auto-coupling out of the picture (pun intended)
4. If it still shows error when in total manual mode, there may be something wrong in the camera itself. Before giving up, do a total system reset on the D90 (I assume you have the manual).
1helpful
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Nikon Coolpix S5 camera. Lens shutter remaining open.
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
Error message
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
7helpful
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
