Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
How do you clean all the cooling coils on the bottom of a side by side model 51252103
  • 112 Answers
Use a vacuum cleaner with the bristles on the attachment.
Posted on Jul 21, 2010
GE Profile 21 cu ft. goes continuously except upon defrost, "once a day" for about 30 minutes. Unit cools both on freezer side and refrigerator side (ice cream ok and milk ok). Repairman...
open the doors and feel the middle strip.if that's hot check the condenser fan to make sure it's running and clean out the coil in the back.pull out the machine,remove the bottom panel,on the right side you'll see the coil,with a shop vac vac off the coil and then put it on blow and blow out the coil,that's the only way to clean this kind of coil and make sure the fan is blowing back there.let me know what you find,also send the full model number,open the fridge door,look at the right wall near the ceiling and you should see the model number.
Jan 23, 2011 | GE Profile Side-By-Side Refrigerator with...
Frost on back of freezer, not cooling right in both boxes
You probably have a defrost heater, timer, or temperature switch failure. The heater is the most common problem. What happens is frost has clogged the cooling coils and very little cold air is being circulated through it to do the cooling. Clean out the freezer and remove the back panel to thaw out with a hair drier or wet vac blower etc. Now find the cause. http://www.appliance411.com/faq/howdefrostworks.shtml
Jan 31, 2010 | Refrigerators
Maytag Model RSW24EOD. Not cooling. Frost on freezer back wall
Low on freon or there may be accumulation of dust and dirt on the coils of the condensor. To check to see if the coils are dirty you need to remove the bottom panel of the fridge just below the frige door. Once you pop off this panel take a flashlight and look under the unit. You will see what looks like a radiator with a fan and fan motor in front of it. If these coils are blocked the unit will not cool since this is where the heat goes from the fridge to be dispersed. Clean the coils with a coil brush (purchased at any hardware store) and use a wet/dry vacuum to remove the debris. Once these coils are cleaned it will take about 12 hours for the unit to operate properly.
If the coils are clean already then you possibly have a compressor that is low on freon. I would check the coils first since most of the time this is the cause of the problem.
Good luck on your repair hope this helped you some
Dave
Jan 29, 2010 | Refrigerators
Artica Profile side by side freezer will not cool below 2 degrees
Remove the rear panel at the bottom of refrig which covers the compressor and coils . The coils should be cleaned about every 4-6 months . Place a length of 2x4 laid flat behind the fridge , to push the fridge against , as this also gives enough room for air circulation .
Jul 27, 2009 | Refrigerators
I have a 10year old Amana 25cu SRV26V side by side and our freezer and food area is not very cold. The freezer side is only 20 degrees. Both sides have been turned up to 7 as high as it can go since...
Hi: It's a sealed system so if you need a recharge it will be expensive. You mentioned that the "air filter" in the back was clean. Do you mean the panel at the bottom of the back of the refrigerator? The coils are on the bottom (parallel to the floor across the bottom) and have to be clean. If you haven't done this; remove the grill and vacuum the coils. It's best to use a coil brush to get to the very back. A refrigerator coil brush is available at Lowes or Home Depot. I use an air compressor to blow them out. Then I have to dust the house. If the coils haven't been cleaned this will cause what you described. I hope this helps, Jeff
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Divider between doors has extreme heat for side-by-side model
there are 2 pipes running there to reduce the temp in the compressor its normal
Jun 16, 2009 | KitchenAid KSCS25FKSS Side by Side...
I have a side by side and the fridge part is not cooling enough.
Sounds like a defrost problem. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator is not cooling
Not sure 100% but try and changing the thermostat control.
May 10, 2009 | Refrigerators
Fridge side not cooling
the coils are at the bottom but that dose not sound like the problem u need to check the de frost
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
114 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
