I recently purchased a Denon AVR-3300 from a friend and cannot get the digital inputs to work. On the receiver I have set up the dvd input to optical or coaxial depending on which im trying. Also on the dvd player I have set up the output correctly. The three options that can be set on the DVD player are Dolby Digital/PCM, Stream/PCM, or PCM only. The only time any sound comes out is when the DVD player is in PCM only but it only shows up as Pro Logic DVD. I have tried different digital coaxial cables and optical cables on two different DVD players and neither would work. Is there anything I am missing or are the digital inputs on the receiver broken?
FYI: DVD Player: JVC XV-N55SL Receiver: Denon AVR-3300 Speakers: Wharfedale 8.1 Diamonds with Wharfedale 8.1 Center
Thanks in advance for any help as this problem is really annoying me.
That is what I have been trying. I am useing the digital out on the DVD player. I have tried both digital coaxial and optical cables and had them both set up right on the DVD player and on the Receiver. The receiver is set to Auto and Dolby Pro Logic as it is supposed to automaticly switch to Dolby Digital or DTS based upon the signal. The only time i can get any sound to come out is when the DVD player is set to PCM only and the receiver is either on Auto or PCM. Additionaly I can not get the test tones to make any sound either which makes me think there is something wrong with the receiver. All other analog inputs work perfectly though.
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Denon AVR-3300 Problem:
Solution #2
posted on Aug 10, 2005
Grant - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
so, let me get this straight, you only get sound when the DVD player is set to PCM, which I believe is straight analog audio (doesn't have to do with the digital outputs. Try this-put a DVD into your machine, choose Bitstream, use one of the digital outputs, figure out how to tell (if need be) the reciever that the DVD is going through one of them, and make sure to set your input mode on the reciever to "Auto" or "Digital". Hopefully, this'll work. If not......
good luck
JB
Solution #3
man1 - usenet poster
You have to go into the setup menu of the denon and specify what items you want attached to that (either coax or Toslink input. read your manual
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =-----
