Question about Maytag MBR1956KES Stainless Steel
Refrigerator section is to warm, the freezer section seems to be colder than it has been and is froming ice around the slide door
  • 4 Answers
Change the heating element in the back of the freezer around the coils
Posted on Jul 23, 2010
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Maytag side by side, freezer working fine, refrigerator not cooling.
If your freezer side is capable of making ice, and that ice is dry and remains so,
the only issue you have is insufficient airflow to the reefer box section from the freezer.
The refrigerator section is 100% reliant upon the frezers side for all of its cold air.
The refer box has no evaportator of its own, There are 2 settings or dials.
One is the temperature thermostat, it actually controls the compresssor motors cycling,
thus the desired ice box temperature as well, it often says 1-10 and off as well, the reamaining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the reefers box!This is where the problems occur, when one notices the reefers box is warm, they max both settings,which seems logical , and is for the thermostat dials setting.Where the major counter intuitive reality exists is the flapper dooors setting will say Colder and Warmer!!Colder of course!! right?? No, it actually means and usually does say, Colder Freezer!!not Colder Reefer! so you MAX or RAISE the thermostat, thats ok to do.But maxing or raising the other setting is just starving the reefer box section from sufficient cold air flow to maintain adequate temps.I have gone to hundreds of identical calls, Freezers ok, but Reefers warm! If the freezers making ice and the ice is dry, there is no problem with the refrigeration system, its airflow.when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm in another day or so. But if the freezers making ice for days and never getting wet theres an airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it iced up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?setting both dials to the midway setting should work fine. the condenser coils may be dirty/dusty too, is the cardboard backing still in place on back? it needs to be there intact.
is there product inside the reefer box? if not add 3 gallons of water.
Dec 27, 2010 | Maytag MSD2355HES Side by Side...
ALARM LIGHT IS FLASHING ON THE FRIDGE.. THE FREEZER IS FINE ..
Dec 27, 2010 | Refrigerators
Our fridge keeps creeping up to 10 degrees Centigrade despite defrosting every week. It must need some fan to keep the air cool and circulating from the freezer which works well?
Dec 27, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge not keeping cold whats the best temp. we only have no.s 1 to 10.
The refrigerator section is 1005 reliant upon the frezers side for all of its cold air.
1 is the temperature thermostat, it actually controls the compresssor motors cycling,
thus box temperature as well, it often says 1-10 and off as well, the reamining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the refers box!
This is where the problems occur, when one notices the reefers box warm they max both settings,
not colder reefer! so you max or raise the thermostat, thats ok to do.
when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm too much in another day or so. But if the freezers making ice for days and never getting wet theres a airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it icedd up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?
is there product inside the reefer box? if not add 3 gallons water.
Dec 27, 2010 | GE Profile PSI23NCR Side by Side...
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Freezer and Ice maker are working refrigerator is not what can be done to the vent thing at the top (center)? I have removed the cover. I have had this happen three times while under extended warranty...
Dec 20, 2010 | Maytag MFD2560HES Bottom Freezer French...
Fridge wont get cold
DEFROST HEATERS2_bing.gif IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING A PART. THERE IS A BROWN AND ORANGE WIRE TO THE DEFROST SAFTY THERMOST. THE CONNECTOR ON THAT BROWN WIRE MAY HAVE FROZE APART. THE DEFROST SAFETY THERMOSTAT MAY HAVE FAILED. OR CONTROL BOARD MAY HAVE FAILED. BEHIND THE KICK PLATE IN A BAG ATTACHED TO THE BOTTOM OF YOUR REF. CABINET IS A TECH SHEET ON HOW TO FORCE A DEFROST TO CHECK THE SYSTEM.
Apr 25, 2010 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Maytag MBR1956KES Stainless Steel Logo
61 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
