Printer tells me my paper tray is empty although it is full.
I just wondered whether the mechanism that picks up the paper to feed paper through the Printer is damaged and would like to know if I could possibly view it, or should I take it into a repairman.
Who is the closest FixYa here in auckland New Zealand.
  • 2,785 Answers
It wil be better to take to repairman as your printer is having hardware problem
Posted on Apr 22, 2008
Lexmark E232, keeps telling me paper tray is empty even though it has paper in the tray, then it just keeps clicking instead of picking up the paper and feeding into the printer? Please help
Go the Lexmark website and search on support for their telephone number. I've always had a experience with their support team even if the printer is out of warranty.
Apr 05, 2012 | Lexmark E232 Laser Printer
Will not pick up paper from normal tray 1 but does pick up paper from larger paper tray 2 despite having error message that tray 1 is empty, it also has a duplexer fitted. If you put paper in tray1 it...
check the tray one paper empty senor blow out with air is the paper acturator broken that the device that would lay on the paper when its out of paper the sensor will drop far enough to tell the printer tray one is out of paper miss feed are the rollers are dirty and or need to be replaced
Jan 14, 2018 | Konica Minolta magicolor 2490MF Laser...
The paper tray always shows empty. Even full of paper . This happens on both trays. Copier works with the side feed.
check pick up assembly,maybe there is something wrong in the mechanical area of that assembly
Jan 05, 2010 | Canon imageRUNNER 210S Copier
My printer is not taking the paper and is saying that the tray is empty. I can hear the mechanism making a sound as though it is going to take the paper but nothing actually moves to do it. It's as if...
Try the feed switch first, the feed switch selects either the top feeder or the cassette under the printer. If it is set for the wrong one you get that error.
Nov 17, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Samsung CLP-300 picking up too many pages
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Aug 16, 2009 | Samsung CLP 300 Laser Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Paper in tray but message says paper tray empty
HP officejets are notorious for problems with paper feeding...
Try the solutions (ignoring the ones about tray #2) from this solution... They're all the same sort of printer feed mechanism.
... also something I noted with the K850 (the earlier model to the K8600).. some papers are less likely to be picked up than others.
I had to get some cheap A3 paper for that unit which worked better than Xerox branded, higher quality photocopier stuff. Sounds strange but if it works...
Hope that lot helps.
Feb 22, 2009 | HP OfficeJet Pro K8600 Printer
Error msg: paper jam or empty paper cassette when it is full
Click on the 'feed switch' on the front control panel- it might be feeding from the invisible drawer underneath and it might be empty. There is a light which will indicate which source it is feeding from.
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Hp p3005n keeps getting paper jam error in tray 2 like every other page it prints and there is no paper jammed. I replaced the printer with a new one and get the same annoying error. So when you printing a...
I had the same problem, the transfer roller rubber was completely slick and would not pick up paper (it would also make a clicking sound).
Replaced it and the problem went away.
Jun 11, 2008 | HP LaserJet P3005n Printer
"Out of paper" error message
i would try clening the paper feed tires and roller and if that dose not work i woudl replace them.also pull the paper tray out adn look in top of the printer where the paper feeds out of the tray to see if the is a peice paper is blocking the sensor that reads that the printer has paper.
Apr 03, 2008 | HP Photosmart 3210 Printer
197 people viewed this question
