The tape deck/recorder section of my Aiwa Stereo 250 boom box has stopped working completely and I want to get it fixed. I live near Boston. Could you please let me know if you know any reliable shop where I could get it repaired? Thanks, Scott
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please provide the ZIP code or whether it is in GA, IN, KY, MA, NY or VA so that I can provide you with area specific details for authorized repair centers.
Thanks
Rylee
Posted on Jul 21, 2010
Aiwa AD F660 cassette deck. Having changed the drive belts, the eject button does not now work. Hook holding the cassette door shut does not drop enough to release. How can I fix this? Thanks, Brian
Have you trapped wire or something near the hook mechanism stopping it from getting full travel when the button's pressed?
The nice people at HiFiengine have a service manual for the deck, free you just need to join.
HTH
Aiwa AD F660 Manual 3 Head Stereo Cassette Deck HiFi Engine
Jan 19, 2018 | Aiwa Audio Players & Recorders
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Feb 23, 2010 | Aiwa Audio Players & Recorders
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
Cassete deck will not work, I put a tape in deck 2 and hit the record button and all it did is started to make a clicking noise. Next I tried to take tape out and the door would not open. I forcefully...
I have a sony twin cassete deck and the same thing happened to mine , it turned out to be the rubber belt inside was broken so i just bought a pack of assorted belts for $7.97 and replaced both belts .
Jun 05, 2009 | Aiwa NSX-A767 Shelf System
My Sony dual tape deck does not record in stereo anymore.
Oxide deposits on heads can restrict audio transfer to tape. You may need to do a deep cleaning of record head. Depending on how much deposits are on heads may need no more than alchohol and Q-tip. Be sure to clean erase head and drive roller. Afterwards, try recording, then use headphones in jack on recorder to check for recording on both channels. If this works, problem is not in rest of equipment set up. If you still need help, email me
Apr 21, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
35 people viewed this question
 Grubhead
Grubhead
