Question about Singer 2732 Mechanical Sewing Machine
The needle is hitting the bobbin - Singer 2732 Mechanical Sewing Machine
    President:
  • 1,514 Answers
Either the needle is not far enough up in the holder or the bobbin is in upside down. Most likely it's the bobbin.
Posted on Jul 21, 2010
Set needle bar height on Futura 900 sewing machine
Um, it most likely is not a problem with the needle bar height but instead an issue with machine timing, ie the needle is arriving at the bobbin at the wrong time. This happens frequently when the needle hits a pin or a dense piece of fabric, deflects the needle, which hits the bobbin mechanism, and the bobbin is out of time. BE SURE you're using a brand new needle--you may even try a couple of new needles because sometimes they are defective out of the package. If the needle is defective (bent, has a burr, etc.) it could also be the problem.
You can search the internet for articles and videos discussing sewing machine timing or take it for service.
Nov 17, 2016 | Sewing Machines
Sewing machine
remove the cover over the bobbin section so that you can see the needle bobbin carrier interaction
now turn the machine over by hand and watch the needle go down and start to come up
at this point the hook of the bobbin carrier should be very close to the needle just above the eye of the needle
It is at this point the the needle thread is picked up and run around the bobbin carrier to link up with the bobbin thread
if it is not there then take it in for an adjustment as the adjustment is done by loosening off the clamp on the vertical bar at the end of the machine that moves the needle up and down and positioning the needle in the position described
if the needle is hitting the bobbin and the timing is correct , replace the needle as it may be bent or not in properly
Jun 24, 2016 | White Sewing 2037 Mechanical Sewing...
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
How to adjust placment of twin needle so it doesnt hit edge of bobbin holder?
The needle should not hit the bobbin holder at all. Do you have the needle inserted all the way? If it is too low, it will hit. If you are saying the needle is hitting the sides of the needle plate where the needle goes through, then the needle is too wide for the plate. Either use a narrower twin needle or see is a needle plate with a wider needle hole came with your machine. Some decorative stitches can't be used with a twin needle because the combination of width of stitches and width of needle is too wide. In that case, narrow the stitch width until the needle doesn't hit the needle plate or use a narrower twin needle. I hope I have helped and answered some of your questions. Good luck.
Apr 26, 2014 | PfaFF Sewing Machines
My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
May 03, 2012 | Singer Sewing Machines
Needle hits bobbin case
If the needle hits the bobbin case the are only 2 things that could be wrong. Lets hope its the easy one, there are more than one length of needles, if the needle is to long or it is not all the way up in the neelde bar, the needle will hit the inside of the bobbin case. Now if that is not the problem then the machine is out of time. ALWAYS check the easy stuff FIRST.
May 20, 2010 | Sewing Machines
My DB2-B797 suddenly has needle breaking because needle is hitting bobbin. I need help with technical specs and needle positioning. PLEASE
Hi
First thing to check is are you using the correct needle, if it is too long this will hit the bobbin holder.
If the needle is the correct one, for some reason your timing is out or the needle bar has dropped lower than it should be.
I can't explain on here how to re-time as it is complicated.
If the timing is out it is very unusual as the working parts are locked in position.
Take out the thread, remove the needle plate and turn the machine over by hand watching the needle and see if it is actually hitting the bobbin or bobbin holder.
Rob
Jan 02, 2010 | Sewing Machines
Needle hits the bobbin casing.
check to see the bobbin is in correctly first, is the needle in the centre?
Nov 23, 2009 | Sewing Machines
Timing the needle
That isn't the timing. If the hook is hitting the needle the hook is too far left - or close to the needle. It's adjustable by loosening the set screw at the base of the hook and by gently tapping the hook away from the needle. You want the hook to be close enough to the needle to pick up the thread loop that's formed just as the needle bar is rising.
Aug 29, 2009 | Sewing Machines
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Singer 2732 Mechanical Sewing Machine Logo
49 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
