Question about Black & Decker Tools & Hardware - Others
I have a Black and Decker KA250K Sandstorm sander, any ideas how u change the bases
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
efs_perpends
  • 1996 Answers
SOURCE: What is the powersource for this sander?
It runs on ac 110v power in the U.S.
You will be able to access the instruction manual and order a new power cord at the following website: http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=36877&typeId=9469&documentId=24796 or
Or you can call Black & Decker directly and get them to provide the part number you need over the phone by following:
IF YOU SHOULD HAVE A QUESTION OR
EXPERIENCE A PROBLEM WITH YOUR
BLACK & DECKER PRODUCT,
CALL 1-800-544-6986
BEFORE YOU CALL, HAVE THE FOLLOWING INFORMATION AVAILABLE, CATALOG No., TYPE
No., AND DATE CODE (e.g. 0130M). IN MOST CASES, ABLACK & DECKER
REPRESENTATIVE CAN RESOLVE YOUR PROBLEM OVER THE PHONE. IF YOU HAVE A
SUGGESTION OR COMMENT, GIVE US ACALL.
YOUR FEEDBACK IS VITALTO BLACK & DECKER
I hope this sorts it out for you...If not, please write back and let us know.
Posted on Mar 26, 2009
efs_perpends
  • 1996 Answers
SOURCE: Where can I get an instructional manual for my
You can view or download the manual here:
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/487931-00,FS520etc.pdf
If that's what you were looking for, please take a moment to rate this post. Thanks!
miket756
  • 2702 Answers
SOURCE: How do I change the sandpaper in my
there are many types of sizes for this sander check you have the right size first,,, after that check that the return springs in the belt tenshioner are poping out fully
Posted on Nov 15, 2009
SOURCE: how do you change paper
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Posted on Dec 04, 2010
I am looking for a manual or parts list for a black and decker U-140 Sander
its listed as a vintage sander
may have to source used ones ... ebay ?
cant find a user manual online
parts might be discontinued
not showing up on the parts list
Black and Decker Sander Parts
Oct 28, 2016 | Black & Decker Tools & Hardware - Others
Can't figure out how to load the sand paper on to the mouse sander
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
Aug 06, 2011 | Black & Decker Mouse Sander/Polisher
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
Hand sander stops spinning once placed on item to be sanded
This sander has a brake pad that is supposed to stop the rotation when the sander is not actually in use. It sounds like it's malfunctioning.
The only other thing I can think could be a cause of what you describe is an improperly assembled sanding base. Have you changed out the base, and if so, were you sure to properly align the replaced base on the machine before you tightened the allen screw?
If you're not comfortable disassembling a tool that is still under warranty ( I think it's two years for that one), I would recommend finding a Dewalt service center and taking it in for a factory service call.
Mar 24, 2009 | Black & Decker Black And Decker Cyclone 4...
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
Tools & Hardware - Others Logo
994 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
James Ryan
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Axel Gringmuth
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
