Question about Crown CE1000 2-Channel Amplifier
THE FAN STOPPED WORKING - Crown CE1000 2-Channel Amplifier
  • 17,130 Answers
If your amplifier is working fine then you need not worry but it willonly be the failure of the fan or the power circuit to the fan. Ususally the fan works only when the temperature of the heating drivers goes up beyond a limit. Hence if the fan is not working at a low temp there is no need to worry. power up the circuit and see if this works. If the atmospheric temp is low the fan will not work unless it is kept inside a closed enclosure. so check this out. Other wise check on the fan with a voltage to confirm. if not chekc on the main board for the thermistor trigger to give voltage to the fan. I hope this will work. Good day
Posted on Jul 23, 2010
Fans stopped working on 2001 kawasaki zx1100
Check to see if fans are working.. if they are replace your thermo switch. Some multimeters have temp gauges on them..check consistency of power to the fans and temperature for the cut in switch.
Hope this helps
Ken
Aug 13, 2014 | kawasaki Motorcycles
Central air unit (the outside unit) works fine then fan stops and makes a buzzing or no noise at all, later works fine again then again fan stops
I would start by testing or replacing the blower motor resistor, it's located next to fan, fan wires goto it. When fan stops try tapping on it. The resistor is more common than the fan
Aug 22, 2013 | 2003 GMC Envoy
I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
Feb 28, 2011 | Ovens
Fan stopped working
The bearings may have gone out in the fan. Try to find an old fridge and swap out the fans.
Oct 13, 2009 | Refrigerators
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
Jul 11, 2009 | House Brand Dryers
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Neff B1861 Single circotherm super...
Fan stopped
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Crown CE1000 2-Channel Amplifier Logo
249 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
