Question about Kenmore 22422 Top Load Washer
Its spinning bit slower - Kenmore 22422 Top Load Washer
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Jul 21, 2010
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Washer spins to a stop.
the brake engages the clutch and no it does not stop right away.
Mar 23, 2014 | Frigidaire FEX831CS Top Load Stacked...
Can i attach a skeg to an inflatable Sevylor/Coleman fastback kayak?
You could probably tie one on using a rope harness over the top of the boat, you can do that on anything, but why would you want to?
It is not going to track really well in any event, and so you will just make it slower. Inflating it rally really well might help. This is a short boat and I suspect a bit high-sided, so it will catch the wind and it is more-or-less flat bottomed so it will spin a bit. (YMMV.)
Jan 09, 2013 | Sevylor Boating
2001 ford windstar the right axle spin slower then the left one. What can be the problem i both two new axle and it stil spin slower then the right but it move better do i need to rebuild the trans
I don't think you can assess the condition of the transaxle by spinning the wheels.
The differential in the transaxle converts power from the transmission to the wheels by a set of gears. It would almost impossible for one side to turn at a different speed than the other.
You may have more drag on the brakes on one wheel, or the fluid in the transaxle could cause one side to go slower with the van off the ground.
Jul 05, 2012 | 2001 Ford Windstar
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
Kenmore washer
Top loader? The basket at rest is slightly to the rear. Slow spin speed could be the brake hanging up or a worn clutch. If these are ok the spin tube bearings may be tightening up. Eric
Dec 04, 2009 | Microwave Ovens
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
"loading" then "no disk"
You might as well just replace the player, the cost to repair is more than a new one.
May 18, 2017 | Coby DVD-218 DVD Player
Kenmore 22422 Top Load Washer Logo
78 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
