Prgramme selector keeps going around, water not been drained from washing machine
  • pablodee32 Dec 13, 2008
    very same problem.have checked all alternatives. must be pump blockage. how hard is it to gain access to pump, remove any obstructions?
    Sergeant:
  • 351 Answers
Blocked pump or pumping problem
Posted on Apr 22, 2008
Not spinning and goes back to start of programme
Sounds like a problem we had on are washing machine. I assume that the you have confirmed that the pump has removed the pre spin water ?
We found the problem that the small pipe to the sensor from the sump area had a split in it. The sensor could not detect most of the water had been pumped out so it kept trying to empty
Jan 08, 2014 | Washing Machines
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
Ariston A1435 washing machine. The prgrammes do not move on.Can select any cycle it washes but stays on the programme and does not move onto the rinse cycle have to manually stop and select rinse and spin....
If the program is put ON does the inlet valve open to let water IN. If so does it after the water is filled to the set level go to wash If yes , then after wash does it drain ? If all the above cycle is true then the program is working correct and a fault in the input can be the reason.
If however there is distruption of the sequence, then each input and drive must be checked to establish if the program controller or the input sensors are faulty.
Please give me a feedback
Sep 18, 2010 | Washing Machines
My washing machine overflowed and would not drain. When it is on water keeps coming in even though the machine is full iof water but there is no movement of the agitator and I could not get it to...
H i there.....sounds like you've got either a failed water inlet valve....or a disconnected /ruptured capillary hose from the pressure switch to the tub....or a failed pressure switch........turn water to appliance off.....turn program selector to drain or drain /spin..is drain pump running...if not it may be blocked or burned out....or with machine empty of water.....turn program to spin....if no spin...check motor....
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washer won't drain and spin
Sounds like the pump is not working.
Select drain only on your prgramme and you should here the pump motor running.
If not, see if you can establish if it has a supply going to it. (if you feel competent)
If it is running, then you possibly have a blockage.Check your filter if it has one.
Please leave feedback.
Thanks.
Dec 06, 2008 | Washing Machines
LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 16, 2008 | LG WM0642H Front Load
INDESIT WD10 WASHER N DRYER WATER WONT EMPTY PLZ HELP
I had exactly the same problem, found the answer on another website. The filter had a small sock stuck in it, stoppin the ppump from turning and draining the water out. Lever off the front panel right at the bottom of the washine machine, then unscrew the round black plug, lots of water will come out. Pull out the black thing and stick you fingers inside and pull out watever is blocking the pump. Turn off the electrics first. Mine now works fine again. :)
Mar 21, 2008 | Washing Machines
Ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Nov 29, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
