Question about Generac 100 Amp 120/240-Volt Transfer Switch #RTSN100A3
Here's the info on the transfer switch. The
Here's the info on the transfer switch. The problem I'm having is the there's no power going to the disconnect switch.
Model- OTPCB-5561924
Serial- E020373703
Spec- A
Current rating 225 A
V-208
HZ-60
3 pole.
    Scholar:
  • 142 Answers
What do you mean by "there's no power to the disconnect switch"?
Is it the feeder from the mains or from emergency generator?
If it is the input from mains and you don't have voltage on it, this should make the generator to start, if automatic start is selected and thus give voltage to the other feeder (emergency), the switch goes on and the consumers have power.
If you have power on your mains feeder, you don't need voltage on your "emergency" feeder. Then the consumers should be supplied by your mains contactor.
Posted on Jul 21, 2010
2005 Silverado 1500 crew cab stuck in 4wd high?
How many buttons on 4X4 switch ? Or doesn't have any . What transfer case does your have ?
Transfer Case - NVG 149-NP3
Transfer Case - NVG 246-NP8
Transfer Case - NVG 261-NP2
Transfer Case - NVG 263-NP1
4X4 light saying lit ? Flashes ?
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel.
The NVG 263 transfer case features a three button shift control switch located on the instrument panel.
Need more info . Could have DTC'S - diagnostic troube codes
DTC B0790
DTC B2725
DTC C0300
DTC C0305
DTC C0306
DTC C0321
DTC C0327
DTC C0359
DTC C0374
DTC C0379
DTC C0550
Aug 26, 2017 | Cars & Trucks
Can't find the transfer switch, and could it go bad. Shore power and generator power works to the main panel box, but won't charge coach batteries
although it is possible to do separately most times the transfer switch is internal to the inverter , and the fact you mention that inverter is not charging batteries tells me your fault lay in the inverter all or part of it is not working , look at it carefully these have sometimes two reset breakers on there cases
Jun 01, 2015 | Inverter Electronics - Others
What size breaker goes into the unit
it depends on what you are talking about,if you need a circuit breaker in the transfer switch,then you cant go over what the amperage of the generator is,if you need circuit breakers for the outlets on the generator,that also varies depending on your generator,if you would of given all the info that we need,i wouldnt have to give you this kind of answer,it couldve been more concise,make,model,s/n of generator,s/n of transfer switch etc.
Apr 16, 2015 | Electrical Supplies
I have a Taylor Perkins 150 KW generator on chicken houses. It will start on manual but not on automatic. Once started manually it won't transfer thru transfer switch.
Go the transfer switch and locate the 2 DC control wires that go to your generator for remote start.(On the remote start terminals) If you jumper these wires in the transfer switch and it starts, then the problem is with the transfer switch. If it still won't start check the wiring from the switch back to the generator, if all ok then suspect the generator control board. I would recommend you have an electrician do this, as there is line utility power in the switch and is dangerous !
Sep 21, 2013 | Taylor Cutler Hammer 3-Phase,...
GE Generator 10kw model #040448. TRANSFER SWITCH FAULT message being displayed. Generator works fine. Generator output load voltage = 233V.
This generator has a built in transfer switch. If you do not have an external source of 240 volts going in to the unit (utility power), the transfer switch will show a fault or "abnormal" reading. If you do have utility power going in to the transfer switch, and the generator is on then you have a faulty transfer switch. It is time to warranty or get a replacement switch.
Sep 09, 2013 | Watts Onan Portable Generator - 5000 ,...
Rv generator output, yet no power in coach. Called Parallax about Transfer switch, yet company says just reset the transfer switch, did now says error fault relay switch. Parallax ats501 why now there is a...
Check to see if you have power going into the switch. This can be done with a voltage meter at the terminals were the cable runs into the transfer switch. Do you have power at the generator plug?
Jan 06, 2010 | Watts Onan Portable Generator - 5000 ,...
Series165 Automatic Transfer Switch with faulty controller
You have a faulty component in the controls somewhere. Sometimes you can find it by unhooking things, then try powering up until it stays on. Then you isolate it down by gradually hooking things back up until your problem comes back.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 20, 2009 | RTO ASCO 165 Series 200A Automatic...
Generac 100 Amp 120/240-Volt Transfer Switch #RTSN100A3 Logo
191 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
