Question about VIA JetWay PM9MS Socket 478 PM800 Micro ATX Intel Motherboard (MBJ9MS)
Purchased dram upgrage 1gb ddr,266,cl2,ecc reg and wont boot why jetway pm9ms
    Guru:
  • 1,705 Answers
I think you've got the wrong type of RAM, its incompatible. Go to this site:-
http://www.crucial.com/uk/store/listparts.aspx?model=PM9MS
Should give you all the info you need.
Posted on Jul 21, 2010
Testimonial: "fast response, I already new the answer, i just didn't want to face it!"
  • dgsturt Jul 21, 2010
    i think you got the wrong type of RAM, its incompatible with you MOBO.
    Go to this URL:-
    http://www.crucial.com/uk/store/listpart...
    It should tell you all you need.
I bought 2 x 1 GB 128M x 72 333MHz PC2700 DDR SDRAM cards to upgrade my HP Compaq dx 6100 MT Pentium 4 Desktop - Upgraded the BIOS as prescribed...BUT if i insert these memory cards in any order in the...
wrong parts, its not support by chipset
Memory
One of the following
2-GB DDR Synch Dram PC3200 (400-MHz) Non ECC (2x 1GB)
Memory Speed Supported DDR Synch DRAM PC3200 (400MHz) non-ECC
Product documentation
Dec 20, 2014 | HP Computers & Internet
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
Can I increase the RAM from 504 to 1008 on my D310m/845G?
Yes you can increase the RAM of your motherboard. It contains two DIMM slots, but can only be upgraded to a maximum of 2-GB ( max of 1GB on each slot.) The slots support DDR Synch Dram PC2100 (266-MHz) and DDR Synch Dram PC1600 (200-MHz) Non-ECC Memory only.
Nov 02, 2010 | Compaq Evo D310M 845G P4 Motherboard
I recently bought ram for my compaq evo d510 sff, but my ram is not detected. as in the computer will not boot at all with the new ram. I borrowed ram from other desktops, and all of them work, one is...
here is what you should have. you cant mix mem types. you are suppose to have what is listed below. maximum amount is 2 gig. have to be pc2100 which is ddr-266
  • Compaq Evo D510 CMT 2GB Memory Ram Kit (2x1GB)
  • 2GB DDR-266 (PC2100) Kit (2x1GB
  • Oct 22, 2010 | Compaq System brd w tray for Evo D510 SFF...
    I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
    Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
    Slot 1
    Slot 2
    Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
    *Not to exceed manufacturer supported memory.
    • 184-pin DIMM Banking: 2 (2 banks of 1)
    • Chipset: Intel 845D
    • Error Detection Support: ECC and non-ECC
    • Graphics Support: AGP 4X
    • Max Component Density: 512Mb
    • Max Unbuffered DDR SDRAM: 2048MB
    • Module Types Supported: Unbuffered only
    • Supported DRAM Types: DDR SDRAM only
    • USB Support: 1.x Compliant
    Q: What memory goes into my computer, and will a faster speed be backward-compatible?
    A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
    Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
    Q: How much memory can my computer handle?
    A: 2048MB.
    Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
    Q: Do I have to install matching pairs?
    A: No.
    No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
    Q: Does my computer support dual-channel memory?
    A: No.
    Your system does not support dual channel.
    Q: Does my computer support ECC memory?
    A: Yes.
    Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
    Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
    Dell PE 1600SC invalid memory configuration detected
    You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
    Oct 28, 2008 | Dell OptiPlex GX280 PC Desktop
    P4S8X-X motherboard. Latest list of compatable RAM 1.gb
  • Chipset: SiS 648
  • 184-pin DIMM Banking: 3 (3 banks of 1)
  • Max Unbuffered DDR SDRAM: 3072MB
  • Error Detection Support: Non-ECC only
  • Graphics Support: AGP 8X
  • USB Support: 2.x Compliant
  • Jul 06, 2008 | ASUS Computers & Internet
    2 x 1GB Samsung PC2100 appearing as just 1GB (2 X 512MB)
    Hi Patrick,
    I see you're point. I know this, you can not run "more than" 512MB in any DIMM slot. That is shown at the bottom of page 10 & the top of page 11. You can not run both types of memory at the same time, even though the chart looks like you could. The description term on page 10, states; Users only can install either 168-pin SDRAM Module or 184-pin DDR DRAM Module at one time. (You can't run both). You can run 4x512MB in all banks using184-pin DDR SDRAM. Or you can run 4x512MB in all banks of 168-pin SDRAMs. Total of 2GB.
    So you can not run 1GB of memory in any bank.
    Mike
    Jun 29, 2008 | Jetway V266B Motherboard
    may be ur pc not supporting 1gb so make it small means get less than 1gb than try.
    Nov 27, 2007 | Intel AC450NX Server
    VIA JetWay PM9MS Socket 478 PM800 Micro ATX Intel Motherboard (MBJ9MS) Logo
    82 people viewed this question
    Top VIA Computers & Internet Experts
    David
    David
    Tony
    Abhinandan  Patil
    Abhinandan Patil
    Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
